dual fuel pumps?
Old Jul 8, 2004 | 07:31 PM
MilanoFury's Avatar
Default dual fuel pumps?
will two 255lph fuel pumps work on a civic? and if so how do you install them? and how much power will it handle?
Old Jul 8, 2004 | 07:45 PM
perlmeister8's Avatar
Default Re: dual fuel pumps? (Crazy18)
why would you need two fp's? The 255lph fp I have heard supports 400hp.
https://honda-tech.com/zerothread?id=919356
Modified by perlmeistere81 at 5:14 AM 7/9/2004
Old Jul 8, 2004 | 08:22 PM
joshwhe's Avatar
you could get it to work rx7 and supra guys do it ..... but man thats kinda over kill i think..... if you really needed that much fuel i would just get a aeromotive or something along those lines
Old Jul 8, 2004 | 08:23 PM
Mase's Avatar
Default Re: (joshwhe)
the walbro 255 will handle 600 hp
Old Jul 8, 2004 | 11:18 PM
TECH43 RACING INC.'s Avatar
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">the walbro 255 will handle 600 hp</TD></TR></TABLE>
easily.
Old Jul 9, 2004 | 05:37 AM
Turbocivic94's Avatar
Default Re: (Mase)
Would u have to modify fuel lines or u can use factory fuel lines. I'm trying to put a little over 500whp and dont want to put big *** Aeromotive. Please let me know what I have to do to push over 500whp with 255lph pump.
Old Jul 9, 2004 | 08:23 AM
MilanoFury's Avatar
I plan on making 500 + hp for the track, and a friend of mine said that his 255 started to have problems around 450 and I don't want a aeromotive just because its big and loud.
Old Jul 9, 2004 | 08:27 AM
Default Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Would u have to modify fuel lines or u can use factory fuel lines. I'm trying to put a little over 500whp and dont want to put big *** Aeromotive. Please let me know what I have to do to push over 500whp with 255lph pump.</TD></TR></TABLE>
no mods needed, you can make over 500 whp with stock feed line, stock return, stock rail, a 255 pump, but you'll need a good regulator, like aem, or aeromotive, a b&m wont cut it.
Old Jul 9, 2004 | 08:39 AM
Default Re: (TECH43 RACING INC.)
I have SX fpr, msd 96lb injectors, Aem rail and running Hondata for management.
Shoud I run stock fuel filter or get a aftermarket one?
Old Jul 9, 2004 | 08:42 AM
servion's Avatar
What about a fuel pump voltage regulator? Has anyone made 600hwp with the 255hp pump with stock lines and stock fuel pump wiring?
Old Jul 9, 2004 | 08:48 AM
Default Re: (servion)
stock voltage is fine. you'll be good.
Old Jul 9, 2004 | 09:08 AM
twkdCD595's Avatar
I see a use for two pumps if your running a surge tank setup.
I have seen the "boost a pump"/ similar modules use more voltage to the fuel pump to increase their flow. I would rather buy a bigger high volume pump before increasing voltage though.
Old Jul 9, 2004 | 09:14 AM
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">I see a use for two pumps if your running a surge tank setup... </TD></TR></TABLE>
HUH?
Old Jul 9, 2004 | 09:17 AM
twkdCD595's Avatar
yeah a surge tank...
https://honda-tech.com/zerothread?id=721357
https://honda-tech.com/zerothread?id=582898
Old Jul 9, 2004 | 09:21 AM
GSRswapandslow.
Guest
Posts: n/a
um, 2 255lph pumps will pump 255lph
Old Jul 9, 2004 | 09:25 AM
twkdCD595's Avatar
Default Re: (GSRswapandslow.)
some people are using surge tanks in road race or high g situations were fuel may be pulled away from the pickup in the stock tank... it also allows you not to have to sump the tank and run new lines.
given I understand that a single pump can sustain x... this is not a design to increase the volume of fuel being flowed.
Old Jul 9, 2004 | 09:28 AM
gotcha
Old Jul 9, 2004 | 09:33 AM
99B16Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. &raquo;</TD></TR><TR><TD CLASS="quote">um, 2 255lph pumps will pump 255lph
um....no
Old Jul 9, 2004 | 09:34 AM
twkdCD595's Avatar
np... it is not a very common setup.
Old Jul 9, 2004 | 09:46 AM
omahaturbocivic's Avatar
In parrallel no
Old Jul 9, 2004 | 05:02 PM
GSRswapandslow.
Guest
Posts: n/a
did they say in parrallel?? i didn't really read much, but in series it'd only pump 255lph
Old Jul 9, 2004 | 05:12 PM
Jared's Avatar
to give you an idea of the dual setup's potential, we just tuned a single turbo supra at the shop that put down 770rwhp with dual intank 255s and new dual -6 feed lines, and that wasnt even pushing the pumps.
Old Jul 10, 2004 | 12:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. &raquo;</TD></TR><TR><TD CLASS="quote">did they say in parrallel?? i didn't really read much, but in series it'd only pump 255lph
They did not say it in the thread but every setup I have seen running dual 255 they are side by side running in parrallel, serial would be pointless. For some domestics they have drop in kits that switch to dual walboro intanks with no modification.
This local guy is planning on running 800+ with this dual walboro setup
I would run something like this before long before I would put up with an aeromotive.
Old Jul 10, 2004 | 03:45 PM
Default Re: (omahaturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omahaturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
hell yeah.
Full-Race Geoff's Avatar
there is not enough space for 2 fuel pumps in a honda gas tank
you need more than stock wiring to support a high power intank
