a couple really easy questions
Old Aug 23, 2002 | 10:33 AM
cjames235's Avatar
Default a couple really easy questions
1. what is the stock boost on a 98 gsx?
2. quick description on how to adjust boost on internal wastegate. i know you turn the rod but cant remember which way makes boost adjust up and down.
thanks for any replys
Old Aug 23, 2002 | 10:42 AM
RGAZ's Avatar
New User
Default Re: a couple really easy questions (cjames235)
1. Computer controlled to somewhere between 12-15 psi. Stock gate is about 7-10psi.
2. Lengthen rod will lower boost, shorten rod will increase boost.
Good enough/
Randy
Old Aug 23, 2002 | 10:43 AM
cjames235's Avatar
Default Re: a couple really easy questions (RGAZ)
so the lowest boost i can put on a gsx turbo is 7 lbs.?
thanks for the quick reply
Old Aug 23, 2002 | 10:52 AM
RGAZ's Avatar
New User
That would be a no. If you can adjust the length of the actuator rod you can go really low. i think if you open the wastegate all the way, i.e. no actuator, the boost will be 4 psi.
Remember, the stock T25 turbo on there does NOT have an adjustable length actuator rod. You gotta do that custom yourself.
Randy
Old Aug 23, 2002 | 11:02 AM
DeepSi's Avatar
1. Correct the stock boost is between 12-15 psi
2. Not sure
-deepsi
nicehatchy
Mar 2, 2007 08:01 PM
motormike40
Jan 3, 2007 02:35 AM
zseeanz
Nov 9, 2003 06:04 PM
stockgreencivic
Apr 10, 2003 07:32 PM
jmad08
Aug 23, 2001 10:41 PM
