could this be piston slap?????
Old Apr 21, 2004 | 07:01 PM
  #26
B18C1CYA's Avatar
Default Re: (turboJody)
no such thing, were the hell are you from? do a search, and if it always sounded that way then y did you lye to me on the phone the other night? you said it didnt sound any diffrent then stock, well your story has changed how come?
Old Apr 24, 2004 | 11:45 AM
  #27
B18C1CYA's Avatar
Default Re: (B18C1CYA)
well went to have my car tuned today by gruvytune and guess what the motor blew up , so no i will be taking it apart and will have pics up of what happend and prove that i was sold a pice of **** by turbojody scammer!!!!!!!!!!!
Old Apr 24, 2004 | 11:50 AM
  #28
m R g S r's Avatar
Yea, that kinda sucks. I know gruvytune is a good tuner, so I doubt it was his fault.
Old Apr 24, 2004 | 11:52 AM
  #29
B18C1CYA's Avatar
Default Re: (m R g S r)
no way in hell its his fault the car was totaly tuned and we were finishing up then the **** blew up.
Old Apr 24, 2004 | 11:55 AM
  #30
Stewie's Avatar
I know it might be too late know, but am I the only moron who knows that the logical thing to do is to check the oil pressure if you think you have rod knock?
Good luck getting everything fixed.
Old Apr 24, 2004 | 11:58 AM
  #31
B18C1CYA's Avatar
Default Re: (Mac8008)
well it fu@ked now so it kinda dosnt matter but the oil pressure was with in the spec 10psi at idel and 3000rpm on 50psi i was only getting 45 psi though.
Old Apr 24, 2004 | 01:07 PM
  #32
TeamCracka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well it fu@ked now so it kinda dosnt matter but the oil pressure was with in the spec 10psi at idel and 3000rpm on 50psi i was only getting 45 psi though.</TD></TR></TABLE>
Thats way to low. Everybody I know gets around 25psi at idle and 75-95psi at the higher RPM's. Is your oil pressure sensor tee'd off with the oil feed for the turbo? If it is then those numbers are fine and similar to what I get, but if it isn't than something was fucked up or clogged up.
Old Apr 24, 2004 | 02:08 PM
  #33
B18C1CYA's Avatar
Default Re: (TeamCracka)
that is t ed with the turbo ,
Old Apr 24, 2004 | 05:21 PM
  #34
hot90honda's Avatar
Default Re: could this be piston slap????? please read updated info (B18C1CYA)
i was there at first start up and there is major piston slap. which i beleve is what caused the motor 2 blow. turbojody = scammer.
Old Apr 25, 2004 | 08:21 AM
  #35
B18C1CYA's Avatar
Default Re: could this be piston slap????? please read updated info (hot90honda)
check my post in the classifieds for the update4/25
Old Apr 25, 2004 | 09:22 PM
  #36
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Stop saying I'm a scammer because it worked just fine with me and the same sound.
i never mentioned the word scammer anywhere
civichhh
May 1, 2014 01:06 PM
nonvtecD
Aug 8, 2009 01:14 PM
verbal assassins
Feb 10, 2007 06:54 PM
theEGkid
Feb 22, 2006 06:43 AM
