Could I install my G Blubox today even thought my kit won't install for 2 days?
I am working on a small time period this weekend when my kit arrives, and I am off today so I figured I could go ahead and install my blue box to save time this weekend by allready having this done, would the car be driveable, and would I need to go ahead and put in the 310 injectors as well?
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (Bimmerman)
ya you can install it it will only add fule when in boost so go ahead and do it.
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (clutch878)
wrong and yes.
You'll run way rich and lose power vs stock. It will add fule the WHOLE time, anytime you touch the gas buebox is adding fuel.
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">wrong and yes.
You'll run way rich and lose power vs stock. It will add fule the WHOLE time, anytime you touch the gas buebox is adding fuel.</TD></TR></TABLE>
Really? I don't know much about the blue box but I would think he would be okay installing it...
You could do it with any other fuel management setup, why couldn't you do it with the blue box?
I think I am going to go ahead and install but what about the injectors?
the blue box only increases fuel pressure when there is boost..
you wont be boosting so you wont have a problem
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (pv2dickman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pv2dickman »</TD></TR><TR><TD CLASS="quote">the blue box only increases fuel pressure when there is boost..
Wrong, it modifies the injector pulse, not bumps up fuel pressure...Anyway, YES, I know for a fact you can install it before the turbo kit...I have a blue box on my car now, and under approx. 20-30% throttle, my wideband stays around 14.-0-14.6, so if you drive it sensibly, it will not affect anything at all..
it doesn't add fuel in vacuum, cuz that doesn't make sense
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (99lspwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr »</TD></TR><TR><TD CLASS="quote">
Wrong, it modifies the injector pulse, not bumps up fuel pressure...Anyway, YES, I know for a fact you can install it before the turbo kit...I have a blue box on my car now, and under approx. 20-30% throttle, my wideband stays around 14.-0-14.6, so if you drive it sensibly, it will not affect anything at all.. </TD></TR></TABLE>
yes.. i was thinking something totally different..
well I drove the car for about an hour to go eat and some other stuff and car seem to run better. Seem to be a little smoother on power delievery. Could it be the injectors being bigger?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bimmerman »</TD></TR><TR><TD CLASS="quote">well I drove the car for about an hour to go eat and some other stuff and car seem to run better. Seem to be a little smoother on power delievery. Could it be the injectors being bigger?</TD></TR></TABLE>
it could be due to the change from old dirty clogged injectors to brand new clean ones?
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
it could be due to the change from old dirty clogged injectors to brand new clean ones?</TD></TR></TABLE>
Or a placebo effect is kick'n in haha
Anyways enjoy the MaD thrID GeAr Vt3c B0osT when you get it installed
Re: Could I install my G Blubox today even thought my kit won't install for 2 days? (HollywoodEG6)
it doesn't add fuel in vacuum, cuz that doesn't make sense</TD></TR></TABLE>
Thanks, but no one like bad information. I drove a blue boxed car around for almost 6 months with zeitronix unit afr/boost lcd display. By 14in its on its way to 10.
fuzzysig
06-01-2017 06:42 PM
jdm98ex
35
04-02-2003 10:48 PM
