Coolent Temps?? Quick Q
Old Feb 18, 2002 | 06:02 PM
TurbodCX's Avatar
Default Coolent Temps?? Quick Q
i need to know what everyone else is running coolent temperature wise. my car seems to run at about 210 degrees F is the normal?? i would like to have some insight on this subject. i am using an autometer guage if anyone is wondering.
thanks
Old Feb 18, 2002 | 06:28 PM
89turboteg's Avatar
Banned
Default Re: Coolent Temps?? Quick Q (TurbodCX)
i was wondering the same thing. my car runs about the same. 210, but if im moving and not really boosting it runs a little cooler. im also using a low temp thermostat. i think its a 175 or something. cant remember.. dean
Old Feb 19, 2002 | 03:06 AM
TurbodCX's Avatar
Default Re: Coolent Temps?? Quick Q (89turboteg)
anybody else????? TTT come on..........
Old Feb 19, 2002 | 06:14 AM
b18bturbo's Avatar
The temp should stay around 200-220 max
with the meziere water pump like i run it usualy hovers around 180
Old Feb 19, 2002 | 06:22 AM
rtype11's Avatar
Yeah that sounds to high, its around boiling point of water, try a bottle of watter wetter, hope that helps, see if you can put your fan on a switch so you can keep it on untill it cools down, check that you timing isnt too retarded which can cause very high cylinder temp/pressure resulting in high coolant temps, if your coolant is old swap it out with a fluch and replace.
just guessing temps my # are all metric and dont feel like converting today.
[Modified by rtype11, 10:23 AM 2/19/2002]
Old Feb 19, 2002 | 06:38 AM
TurbodCX's Avatar
Default Re: Coolent Temps?? Quick Q (rtype11)
210 degrees f isnt that hot, that is whaen my fans start to cut on so tha has to the factory operating temps, it is reall wierd, i can be driving along and the temp will go up to 210-220 and the all of sudden the temps will drop off to 180 in about 2seconds. what the f***k is going on?? air pocket?? head gasket??( runs to good through) how did you guys bleed your cooling systems??
shogun1552
Feb 12, 2013 07:38 PM
brokenojoke
14
Jan 14, 2008 07:37 PM
JDM.DEEBO
Nov 23, 2007 09:24 PM
VTECisSeXY
May 31, 2005 05:32 PM
9K
Jan 7, 2002 05:16 PM
