why does my temp go high
Re: why does my temp go high (JDM.DEEBO)
Just under 1/2 is where it SHOULD be sitting. Have you replaced your thermostat recently? It could have been stuck open and somehow it got un-stuck and is now working properly.
Engines run better and are more efficient when at proper operating temperature. On the water temp gauge, that is just under the 1/2 way mark.
Re: why does my temp go high (PatrickGSR94)
i thougt it was mine thermostat too....but i just change a brand new one....and still sit at lil under 1/2...it suppose too be a good thing????????
Re: (strtrcr77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strtrcr77 »</TD></TR><TR><TD CLASS="quote">Mines goes down to when i floor it maybe cause its cold out??</TD></TR></TABLE>
nope, could be a lot of things wrong with your cooling system. perhaps a headgasket?
It goes down when you floor it because when the engine is under more stress, the water pump will be working harder and thus the coolant circulates faster.
Re: (alexisthemovie)
what exactly do you think would cause that? acura says nothing is wrong when I know this isnt normal. im goin to change the tstat, but im def not a car guy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.DEEBO »</TD></TR><TR><TD CLASS="quote">i thougt it was mine thermostat too....but i just change a brand new one....and still sit at lil under 1/2...it suppose too be a good thing???????? </TD></TR></TABLE>That's the temperature it's supposed to be at. So if it's just below half way... you're good.
