coolant lines for gt turbo
Remove the two coolant lines that go to the throttle body and reuse the 2 nipples to run hoses to the turbo.
The coolant to the throttle body is really only there to prevent the throttle from icing over in cold climates. You won't need this option with the turbo because the intake gasses will be hotter than ambiant.
