Running Coolant
Old Nov 9, 2001 | 06:07 PM
whagkangmakulet's Avatar
Default Running Coolant
how hard is it to run coolant into my T3? I have a custom Turbo setup, where do you guys connect your plumbing?
Old Nov 9, 2001 | 07:49 PM
D-Man's Avatar
Default Re: Running Coolant (whagkangmakulet)
i dont think anybody(well,except you) uses coolant flowing thru turbo unless they're drivin a saab or volvo or some other kind of stock turbo car
Old Nov 9, 2001 | 08:00 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Running Coolant (D-Man)
What I did was bypass the throttle body. So you have coolant that runs from the IAC to the throttle body(bypass throttle body) then into the turbo. The the outlet of the turbo to the coolant fitting under the vtec sylinoid(sp).
art
Old Nov 21, 2001 | 02:14 PM
Default Re: Running Coolant (Arturbo)
eyy Arturbo! Thanks.. one question for you? I have a T3 Turbo and i was wondering where did you get you plumbing that's connected on the turbo?
Old Nov 21, 2001 | 03:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
I purchased the water cooled bearing housing from Majectic turbo http://www.majesticturbo.com and I purchased all the plumming for it from http://www.anplumbing.com and http://www.bakerprecision.com
art
00boost
Jan 26, 2005 06:33 PM
91glassycrx
Jun 28, 2004 07:29 PM
You_Get_Vapors
May 4, 2003 06:17 PM
GruvyTune
Sep 6, 2002 05:09 AM
austrian type-R
Feb 16, 2002 05:19 PM
