coolant overflow bottle problem!
Old May 24, 2006 | 01:42 PM
94turbosi's Avatar
Default coolant overflow bottle problem!
hey guys wondering if u can help me out i got a b20 z10 sleves o-ringed fresh head has been machined and checked for leaks gsr . fresh head bolts after a few passes car will not overheat but coolant overflow will pass its max point and at times it will spill ive done a leak down on each individual cylinder for 10 min each ok no bubles on coolant leak test ok possible do to poor air flow ?or coolant lines on turbo ? the way there routed making high preesure wondering if anyone had this problem ? maybe theres a better way of rounting coolant lines ?i have mines from back of coolant pipe to the top radiator hose on the nipple gsr head by bleeder bolt thanks .
Old May 24, 2006 | 02:54 PM
platinum00's Avatar
Default Re: coolant overflow bottle problem! (94turbosi)
is your radiator cap good?
are you boosted when you see coolant in your overflow?
platinum
Old May 24, 2006 | 04:47 PM
Finland's Avatar
I'd start with a new radiator cap.
Old May 24, 2006 | 08:55 PM
LilCivic04's Avatar
Default Re: (Mr. Helsinki)
i had the same thing, check radiator cap, thermostat... if those two don't wory it could be a headgasket. which in the worse case scenario, that happen to me i changed it and the over fill stopped happening. it happen on my freshly built motor to man
Old May 24, 2006 | 09:03 PM
Mr.Death's Avatar
Default Re: (LilCivic04)
I'm having the same problem as you and I just replaced my rad with a Fluidyne. I'm also losing coolant somewhere. I'm thinking head lift.
Old May 25, 2006 | 11:05 PM
sir boostalot's Avatar
Default Re: (Mr.Death)
I was overflowing too one time, and I switched to aFluidyne radiator, switched thermostat, radiator cap, and slim fans only to find out it was the headgasket all along.
Old May 26, 2006 | 03:03 AM
turbotime's Avatar
rad cap, headgasket
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
DelSol-B18
27
Jun 27, 2013 04:16 PM
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
budget
Apr 9, 2005 05:13 PM
budget
Apr 9, 2005 03:59 PM
