Converting To External Wastegate. How to block hole?
Old Dec 14, 2004 | 10:50 AM
1 Cam Wonder's Avatar
Default Converting To External Wastegate. How to block hole?
Ive got a t3 .60/.63 snail, havent put it on yet but Im going to be runing a tial 38mm external gate. Now I have to plug this quarter sized hole right?
Do I need to buy a new downpipe or is there some sort of plate that goes inbetween the exhaust housing and the downpipe?
Hoping for someone to go over it visually with me
thanks
Old Dec 14, 2004 | 11:50 AM
Sonny's Avatar
Default Re: Converting To External Wastegate. How to block hole? (1 Cam Wonder)
The internal wastegate should have a flapper door. Just close the door and tack weld it in that position. You can also lock it shut from the outside (using the flapper door arm).
Sonny
Old Dec 14, 2004 | 02:43 PM
SOHC_MShue's Avatar
what he said..just weld that flap shut.
Old Dec 14, 2004 | 09:59 PM
Default Re: Converting To External Wastegate. How to block hole? (SOHC_MShue)
hmmm, Ill take some pics in the morning just to be sure, I ddint have a clue people did that
Old Dec 14, 2004 | 10:23 PM
SOHC_MShue's Avatar
yea my friend's old setup had this done to it.
Old Dec 14, 2004 | 10:41 PM
I wanna try this way, one sec Im gonna snap a few pics
Old Dec 14, 2004 | 10:48 PM
nevermind, ittl work perfect
Im just gonna cut off the little flapper and weld it to my exhaust housing
Dont see why it wouldnt work
I dont wanna just weld the door shut because I want to get rid of as much clutter as possible and the exhaust housing Im using is from the same size turbo, but different units, so I wanna be sure its sealed
Thanks guys
vtecguy01
Dec 29, 2005 06:42 PM
SPOOLINmatt
Jan 12, 2005 07:51 AM
DA-MAX
Jan 29, 2004 05:55 AM
B18badboy
Nov 26, 2003 11:57 PM
stockgreencivic
Apr 6, 2003 06:32 PM
