Converting to external coil worth it?
Old Sep 10, 2002 | 09:24 PM
boomslang's Avatar
Default Converting to external coil worth it?
Any experiences with the MSD external coils? Do you have to use one with the standard MSD 6A ignition box, or should you?
Car will be pushing 500+.
Old Sep 10, 2002 | 10:27 PM
SIK IN DA HED's Avatar
New User
Default Re: Converting to external coil worth it? (Inlinefour)
MSD external coils help supply a more powerful spark... supposedly because it can contain more juice than the stock internal coil. i ran one without a MSD amp for sometime.
the amps are a good addition... mainly to smooothen the power band and increase gas mileage.
Old Sep 10, 2002 | 10:46 PM
sleepercivic's Avatar
Default Re: Converting to external coil worth it? (dlplayboy)
i felt it was worth it due to how shitty stock ones are.
TERRY
Old Sep 10, 2002 | 11:55 PM
bigstatik's Avatar
Default Re: Converting to external coil worth it? (sleepercivic)
after market ignition with MSD cap cured all my miss problems at 14 psi and up.
Old Sep 11, 2002 | 07:27 AM
boomslang's Avatar
Default Re: Converting to external coil worth it? (bigstatik)
Anymore thoughts?
Old Sep 11, 2002 | 10:04 AM
93LSivic's Avatar
Ive been thinking about running an external coil along with my hondata also. No MSD box, just the cap and coil. Im experiencing a crazy miss at full boost and think it's the stock coil going out.
Old Sep 11, 2002 | 11:52 AM
lucas569's Avatar
Default Re: Converting to external coil worth it? (93LSivic)
could be your gap too, ive always wondered if just changing out the coil would be a step up as well, imo the ignition is pretty good but the coil itself sucks, even the spot for it is not good.
Old Sep 11, 2002 | 11:58 AM
bigstatik's Avatar
Default Re: Converting to external coil worth it? (lucas569)
like i said, replaced coil and etc, and all probs went away
Old Sep 11, 2002 | 12:17 PM
The_Head's Avatar
I had to get an external coil because I kept on burning up internal coils for some strange reason. Like 2 in one week.
jsnm
Nov 10, 2005 10:39 AM
ATS*Mark
Jan 31, 2005 08:11 PM
_oemek_
Aug 16, 2004 04:16 PM
marques4130
May 9, 2003 06:24 PM
