converting cfm to whp?
Old Jan 30, 2009 | 10:31 AM
turbo-crx's Avatar
Default converting cfm to whp?
how do you convert cfm of a turbocharger to whp?
Old Jan 30, 2009 | 10:35 AM
Schister66's Avatar
Man U FTW
Default Re: converting cfm to whp?
You convert from CFM to Lb/Min and then convert to whp. The general rule is that per 1 lb/min flow, it's approximately 10bhp. I used to know how to do it off the top of my head, but not anymore. Also, i'd search it for you, but I'm in class and somewhat trying to pay attention lol. This should at least give you a little better idea of how to start finding your answer.
Old Jan 30, 2009 | 11:50 AM
turbo-crx's Avatar
say if a turbo flows 1000 cfm, how would i calculate that in lb/min?
Old Jan 30, 2009 | 12:40 PM
LSVtechnologytur...'s Avatar
searching is a crazy thing..
this might help
https://honda-tech.com/forums/forced-induction-16/how-read-compressor-map-142398/
Old Jan 30, 2009 | 01:00 PM
TheShodan's Avatar
Moderator
CFM /14.2 = Lbs/min.
Lbs/min *60/12.5/0.5 = Flywheel HP (generally)
Old Jan 30, 2009 | 01:08 PM
KeyserSoze's Avatar
Multiply cfm by (0.070318) and that will get you lb/min.
*This assumes 112 deg F and sea level.
I have seen people use from .069 to .072 The diff really isn't THAT big a deal for what you are doing.......
Old Jan 30, 2009 | 01:15 PM
turbo-crx's Avatar
so i get 70lb/min with my calculation. so it could make alittle over 700whp?
Old Jan 30, 2009 | 02:46 PM
KeyserSoze's Avatar
Whenever you can listen to this guy ^^^^
He knows a whole lot more than most of us will ever care to know about turbos.
According to his calc the answer is ~676 fwhp. Remember that is not wheel hp. I forget what most people use but it isn't uncommon to lose ~13-15% through the drivetrain. This will vary depending on your tranny and axels. That would net you roughly 588-574whp.
As LSV stated though, a search and a bit of reading will do you worlds of good. Then you will understand what the numbers mean instead of just getting us to crunch numbers for you. GL.
Old Jan 30, 2009 | 02:57 PM
turbo-crx's Avatar
well i did get 676whp, i just rounded up
Old Jan 30, 2009 | 02:58 PM
turbo-crx's Avatar
how many cfm's do gt4294 flow?
Old Jan 30, 2009 | 03:00 PM
KeyserSoze's Avatar
Sigh, once again that number is FLYWHEEL hp. That is not whp. Re-read what I wrote and it would behoove you to take a look at that link that LSV put up and study it.
nd8ch
Aug 4, 2006 11:11 AM
Syndacate
Jul 14, 2006 08:14 AM
Dj Skidz7
Apr 26, 2006 03:23 AM
FastSS
May 19, 2003 08:18 AM
TurboITR296
Aug 30, 2001 03:46 PM
