constructive criticism needed on poorman type r build
Old May 2, 2010 | 08:31 PM
bakomack's Avatar
Default constructive criticism needed on poorman type r build
I have a b16 with ctr pistons and built head right now. have 5k miles on motor but want to build something else cause im bored.
so far ive acquired a few parts for the new build.
98 gsr block 82mm bore
knife edged ls crank
moroso pan and pick up brank new oil and water pump and seals
arp head studs and all the nuts and bolts to put it all together.
now im going to use stock length eagle ls rods but im not sure on what pistons to use at this point. im going to turbo this motor and will be a dd on pump gas and will be at the track every chance it gets.
the head im going to use is the head I already have.
00 b16 head
completely rebuilt
new style LMA's
new valve seals
brian crower SS swirl flat faced valves
blox duel springs and retainers
jun stage 2 cams
aem tru time can gears
P&P
hondata gasket
blox intake manifold
omni power 70mm tb (head intake mani and tb are port matched and flow tested)
blox adjustable fpr
rc 550's
stock fuel rail :-)
on s300 and will be tuned
now I have no idea what kinda power to shoot for here as I dont have the turbo or any of the components yet. what kinda power will this motor handle and what kinda turbo set up do you guys suggest?
thanks for the input
Old May 3, 2010 | 06:36 AM
th3pwn3r's Avatar
Default Re: constructive criticism needed on poorman type r build
It will handle as much as a good tune will allow. Poor tune will result in an engine that doesn't last as long which is kind of obvious. Anyhow, you're going with a fully built setup from the sound of it, many factors will come into play when saying how long or how much it can sustain. If you drive your car like an old lady it will probably last longer even if it has the ability to produce 800hp. What are your goals with this car? I missed it in the original post.
Old May 3, 2010 | 11:22 AM
XxRoCkMaNxNEOxX's Avatar
Determine your power goal...you will get more criticism if you give us that. Also is this a DD or street/track or track only. Your fuel setup will determine your power goals. 550cc will probably give you about 400hp.
Old May 3, 2010 | 08:45 PM
bakomack's Avatar
this is a dd but obviously gonna see its share of races. im thinkin around 350 on pump gas would be nice to play with, I would like to keep the boost at a safe level to not blow the thing up after a few weeks of abuse
Old May 4, 2010 | 03:44 PM
the injectors you have should be fine. you can grab a 57trim turbo should have good spool
Old May 4, 2010 | 07:28 PM
bakomack's Avatar
is 350 obtainable with this motor, i think im gonna use some aries flat top pistons to put me at 9:1 comp.
Old May 4, 2010 | 07:32 PM
The setup that you have is pretty good. You could even get to 500 or 600 if you really wanted to but its up to you. If you plan on going higher I would get the blocked sleeved since its already off the car but if you plan on making 350 then that will do. If you want to make more power its up to your fuel setup and turbo charger.
Old May 4, 2010 | 07:48 PM
bakomack's Avatar
I mean if its capable of more its always nice to know its there you know what I mean.
what other supporting mods would i need besides fpr, injectors, fuel pump?
HyperFlow
Nov 3, 2010 03:49 AM
slick1851
Jul 24, 2010 03:05 PM
slick1851
Jul 6, 2010 06:43 PM
slick1851
Jul 6, 2010 01:33 PM
slick1851
May 7, 2010 09:45 AM
