How to connect Down Pipe to CAT?????????
Old Jan 29, 2003 | 02:46 PM
ImAcracker's Avatar
Loved
Default How to connect Down Pipe to CAT?????????
Hey guy's. I just got my DP today and I was looking at the flange to connect to the CAT. How are you supposed to connect it to the CAT? I dont see a lip for a donut gasket. Am I supposed to bolt it straight to the CAT without springs? Is that what the flex pipe is for? Or am I supposed to get the cat modified? Thanks for any input guys.
Old Jan 29, 2003 | 03:34 PM
BlueSi2k's Avatar
Default Re: How to connect Down Pipe to CAT????????? (ImAcracker)
I would think you wouldn't need the springs with the flexpipe...i would just bolt it up like that.
Old Jan 29, 2003 | 04:51 PM
JMinSi2000's Avatar
I didn't use springs on mine. I got a little aluminum flange to go in there though.
Old Jan 29, 2003 | 05:53 PM
bottlefedb18c1's Avatar
to what i beilive that the bolts with the spring take up the flexing action but now you have the flex pipe so i would gess that you dont need them
and if you use the doughnut i beilve it is alot smaller like a 2 1/4 if not smaller and that wouldnt be very good
Old Jan 29, 2003 | 06:01 PM
Smashback's Avatar
You should probably have a matching welded onto your cat...that's the same type of flange I'm using on my new dp and I'm also using a regular gasket (not a donut). You're not going to use the stock cat, are you?
Old Jan 29, 2003 | 06:45 PM
ImAcracker's Avatar
Loved
Default Re: How to connect Down Pipe to CAT????????? (Hatchblack)
OK. So are you saying that I need to get an identical flange that is on my downpipe and get it welded to my CAT. Then put a gasket inbetween there? And no I am not using my stock cat. Thanks for the reply's.
Old Jan 30, 2003 | 07:10 AM
ImAcracker's Avatar
Loved
So is this what the flex pipe is for to replace the springs. Looking for more opinions. Thaks.
Old Jan 30, 2003 | 07:29 AM
Smashback's Avatar
Right, if you're not using a stock cat, just get an identical flange to weld to your cat and bada bing.
Old Jan 30, 2003 | 01:47 PM
ImAcracker's Avatar
Loved
Bada boom.
Thanks.
hastingsr
Jun 4, 2009 10:04 AM
azn_88
Jun 15, 2008 09:49 PM
SIK IN DA HED
Jan 2, 2003 01:02 PM
J-g-D-s-M-r
Oct 30, 2002 08:08 PM
QuestRacing-TypeR
Apr 2, 2002 02:04 PM
