compressormaps
Old Feb 26, 2007 | 03:26 AM
anton_'s Avatar
Default compressor maps
i have figured out that my engine takes 33lb/min at 8500rpm and 15psi of boost
and 21lb/min at 6000 rpm and 15 psi boost
i think that the t04e 50trim compressor would be the best because the spot when i get to 8500 gets in the midle of the map
http://www.turboneticsinc.com/cm_e50.htm
am i wrong?
Old Feb 26, 2007 | 05:59 AM
HiProfile's Avatar
Default Re: compressor maps (anton_)
It would probably be a great mix. The 50trim can do 400 easily, and has a huge 'island' above 78%. Something like the super60 T3 would be too small, and others like a t3/t04b s-trim that come in-between aren't as efficient. People always want to go the 57trim, but thats rated at 49lb/min, whereas the 50trim is rated at 47lb/min - tiny increase when you also consider its main efficiency island is smaller, and only 76%
ajusaf
Apr 26, 2005 04:57 PM
Del_Slowest
Oct 27, 2004 12:08 PM
BOOSTEDCIVICD16
Jan 29, 2004 04:40 PM
DB2
Jun 15, 2003 07:53 AM
EH2LS
Jun 2, 2003 07:07 PM
