Compressor surge with BOV
Old Apr 19, 2004 | 11:12 PM
turtle-eg's Avatar
Default Compressor surge with BOV
I just installed a TurboXS RFL bov in my charge pipe between the intercooler and tb, but I'm not getting any blow-off from it, it just seems to surge from the turbo, just like when I didn't have a bov. I have the vacuum line hooked up to the back of the manifold with it's own like(no tees). Also I didn't put any washers in the bov. Could it be because I'm only running 7psi of boost?
btw, I did check the bov with vacuum and the piston does move easily upward with vacuum and harder to move with no vaccuum.
Old Apr 20, 2004 | 01:27 AM
99blusi's Avatar
Default Re: Compressor surge with BOV (turtle-eg)
On my TXS type S, I smear a little bit of grease around the cylinder when I do oil changes, helps it open up...it doesn't seem to like to open without it.
Old Apr 23, 2004 | 11:36 PM
Vtec92Civic's Avatar
Default Re: Compressor surge with BOV (99blusi)
what exactly is compressor surge . . . I tried searching and this is the only topic that comes up.
Old Apr 25, 2004 | 06:38 PM
scatuli's Avatar
Default Re: Compressor surge with BOV (Vtec92Civic)
instead of the compressed air going out the bov it is forced back into the turbo causing it to SURGE.
Old Apr 25, 2004 | 06:42 PM
b16ahybrid's Avatar
Default Re: Compressor surge with BOV (scatuli)
Compressor surge is when the throlle plate closes and it sends a surge (wave) back towards the turbo. If this surge isn't intercepted by a blow off valve it can cause the turbo to spin backwards and put extra strain on the bearings of the turbo. Basically it's not good for the turbo or performance
Old Apr 26, 2004 | 05:14 PM
scatuli's Avatar
Default Re: Compressor surge with BOV (b16ahybrid)
thanks for the elaboration
k20powered
May 10, 2010 11:37 AM
MiKeAhOwSkI
Oct 13, 2005 06:02 PM
TurboNubi
Apr 13, 2003 02:18 PM
APEXI Si
Feb 11, 2003 10:27 AM
TURBOED-TEG
May 1, 2002 08:00 PM
