Compressor map question.....
Old Oct 16, 2002 | 12:56 PM
Armed Ferret's Avatar
Default Compressor map question.....
In reference to this thread, when perusing a few compressor maps, i noticed that, assuming b18c @ 84mm bore (2.0L) boosting 15 psi, the 4k rpm (50% max) line crosses the pressure ratio left of the surge line.
Is this a bad thing? (trying to learn as much as possible before inveseting the money.........a.k.a. doing it right the first time. )
EDIT: Some more info:
T04E 60-trim compressor
8k rpm:
Flow @ 15psi = 541.94 CFM (38.11 lb/min)
PR = 2.02
6k rpm:
Flow @ 15psi = 406.46 CFM (28.58 lb/min)
PR = 2.02
4k rpm:
Flow @ 15psi = 270.97 CFM (19.05 lb/min)
I'm sure there's something very simple that i'm not realizing, so bear with me. Baywatch is on, so I can't be expected to focus ALL my attention on this right now.
[Modified by zoomintegra, 2:00 PM 10/16/2002]
Old Oct 16, 2002 | 02:18 PM
Default Re: Compressor map question..... (zoomintegra)
anyone?
Old Oct 16, 2002 | 02:44 PM
Speedworks801's Avatar
My (educated guess) on surge limit is you are exceeding or falling below the pressure it takes to spin the turbo. Make sense? If you fall below, nothing happens, you just don't make boost. If you go beyond the surge limit, you just make some heat and reach max boost. Beyond the surge limit also generally overspins the turbo and can lead to premature failure.
I am no turbo technician, but I hope this helps you.
You could also talk to Terry @ www.innovativeturbo.com
These are the guys I use to build turbos and answer specific tech questions. I think you'll find him friendly and helpful.
Old Oct 16, 2002 | 03:08 PM
Default Re: Compressor map question..... (Speedworks801)
thanks, it actually looks like i'll be good to go.
erikiksaz1
Jun 12, 2007 10:32 AM
JCushing
Oct 4, 2002 03:34 PM
sweettooth
Apr 27, 2002 08:33 AM
Eric J
Jan 1, 2002 03:38 AM
bigTom
Aug 6, 2001 07:49 PM
