compressor map help
Old Apr 9, 2003 | 12:54 PM
Mr. Softee's Avatar
Default compressor map help
I have been told two ways to determine your lbs per air on the x axis.
Thisis from hondavision:
R x D x 0.5 x V x B
1728
R = Max rpm the engine spins up to
D = Engine displacement in cubic inches
V = Natural volumetric efficiency of the motor
B = Absolute pressure ratio (Atmos + boost)
So...
An engine that maxes out at 8000 rpm, has a displacement of 110 cubic inches, with an inclination for 85% VE and running 7 psi of boost would be calculated like this...
7 psi = 7 + 14.1 = 21.1 / 14.7 = 1.48 pressure ratio
8000 x 110 x 0.5 x .85 x 1.48 / 1728 = 320 cfm
1 lb. of air = 14.285 cfm
Therefore, 320 cfm = 22.4 lbs.
Theyalso had another formula that someone pointed out as wrong...
is this the right way? also is .85 the natural volumetric efficiency for a b18b / b18c1? It this the same thing as the ratio of whp to motor hp?
erikiksaz1
Jun 12, 2007 10:32 AM
shadyGs-R
May 28, 2006 12:54 PM
eddyboy
Sep 13, 2004 12:58 PM
Nextelbuddy
Sep 10, 2003 06:07 PM
