quick FJO install ?
Old Apr 9, 2003 | 10:01 AM
trbob16a's Avatar
Default quick FJO install ?
I have searched and printed a number of these FJO install guides off h-t but still have questions.
Everything is hooked up except for connecting the stock O2 sensor to the FJO unit. I will never be running a stock 02 sensor, only the wideband.
There is a solid gray wire on the 4 plug from the FJO, and a white/gray on the 4 plug from the FJO, where do these go?
On the OEM harness there is:
yellow/black
white
black/white
green/black
Where do all of these connect? I have a 1k resistor, just not sure which two to put it between and where to connect them, if at all, into the FJO.
Thanks a bunch for the help. Specific replies like "gray to white, gray/white to black/white with resitor between black/white and green/white" are welcome
Old Apr 9, 2003 | 11:03 AM
gritsak's Avatar
Default Re: quick FJO install ? (trbob16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbob16a &raquo;</TD></TR><TR><TD CLASS="quote">I have searched and printed a number of these FJO install guides off h-t but still have questions.
yellow/black
white
black/white
green/black
Thanks a bunch for the help. Specific replies like "gray to white, gray/white to black/white with resitor between black/white and green/white" are welcome </TD></TR></TABLE>
your post is confusing..why are you trying to hook up the stock o2 sensor to the fjo? the fjo should have a totally separte wideband sensor that it uses (the whole reason you get one)...it doesnt have anything to do with the factory o2 sesnor that the ecu uses to adjst a/f...
unless you mean you are using one of the honda wideband sensors with the fjo unit, which ive got no idea about
Old Apr 9, 2003 | 11:21 AM
trbob16a's Avatar
Default Re: quick FJO install ? (gritsak)
my understanding was that the FJO unit has the outputs that I need to connect, and that I splice those into the factor O2 wiring to provide the 02 sensor data for the ecu. I don't actually want to hook up the sensor, just the wiring so the ECU gets the signal.. sorry for the confusion
Old Apr 9, 2003 | 11:26 AM
TurboTegB18c's Avatar
Here's a link by jeff that explains exactly what you need to do.
https://honda-tech.com/zerothread?id=465176
Old Apr 9, 2003 | 01:08 PM
boosted hybrid's Avatar
Default Re: quick FJO install ? (TurboD16Z6)
Here is the link of that article on my website as well: http://www.boosted-hybrid.com/tech1.html
Old Apr 9, 2003 | 01:14 PM
trbob16a's Avatar
Right I was going off that article. Thing is, I don't have a
blue wire off the fjo harness or a
green wire off the fjo harness
or
two black wires on the honda plug
&lt;sigh&gt; being color blind is a bitch...
DJaeMac
Mar 18, 2009 02:10 PM
EJ8 Kenobi
May 13, 2007 11:29 AM
vtec.dc2
Oct 28, 2006 02:13 PM
r7
Jul 29, 2003 05:25 PM
