compression for turbo build
Old May 22, 2007 | 06:11 AM
iheartmyej8's Avatar
Default compression for turbo build
im bout to start my build. im goin to get forged internals, im building a lsv turbo. my main question is if i buy pistons that r 10.5:1 c/r for a ls motor. whats the c/r goin to be on a lsv? with a b16 head. higher or lower?
thanks
Old May 22, 2007 | 06:12 AM
92redhatch's Avatar
im running 9:1 compression on my 84 mm ls/vtec
Old May 22, 2007 | 06:39 AM
noboostedEGo's Avatar
Default Re: compression for turbo build (iheartmyej8)
if you buy 10.5:1 for an ls motor, the cr will be higher with a b16 head
Old May 24, 2007 | 05:30 PM
Default Re: compression for turbo build (noboostedEGo)
so if i get 9.5 i should be koo, right? im lookin to some pretty high numbers. im gettin a nice turbo too.
Old May 25, 2007 | 09:47 AM
sp00led's Avatar
I would probably get 8.5-9 since it appears the head will raise it some. There are people out there with high compression turbo setups but it just raises the chances that you will run into detonation. Make sure you tuner is comfortable doing this before you buy the parts.
More boost is the answer for big power numbers not a higher compression ratio.
ChrisYuki
Aug 16, 2015 08:19 PM
civic-r11
Mar 31, 2009 12:04 PM
the.hamburglar
May 25, 2006 10:52 AM
Simple
Nov 10, 2004 07:45 PM
Flexin5
Aug 31, 2004 02:58 AM
