is the compression too high?
Old Mar 6, 2010 | 09:36 PM
Dave_Dc2's Avatar
Default is the compression too high?
my new build consists of a built gsr b18c1
components:
sleeved, forged pistons,rods,head studs,skunk2 valves and valvetrain
10.2:1 wiseco pistons, heads been resurfaced a couple of times as well as the block
whats the highest i can boost safely? turbo is a greddy 18g
Old Mar 6, 2010 | 09:47 PM
Stine's Avatar
Default Re: is the compression too high?
Your only limitation will be the fuel you run.
Old Mar 6, 2010 | 10:25 PM
Kelvin Racing's Avatar
Compression isn't high at all. But, the other limitation will be that 18g.. Go BIG or GO HOME!!
Old Mar 7, 2010 | 04:58 AM
street_ride14's Avatar
you're planning to tune this setup right ?
your tuner can work with that compression ratio.
a built block and only a 18g ?
what is your power goal ?
Old Mar 7, 2010 | 05:02 AM
Kyle R's Avatar
I'm also curious. Planning to upgrade in the future?
Old Mar 13, 2010 | 11:25 AM
supa_vi's Avatar
Hey your build is similar to mines sleeved 10:2 pistons brian crower valve train gt35r turbo. 14psi on 91 i have no issues what so ever only issue is im buying tires often ;
Old Mar 13, 2010 | 11:47 AM
Similar? I don't think so.
gt35r and 18g .. big difference.
Old Mar 13, 2010 | 12:46 PM
supa_vi's Avatar
i was reffering to the builds not the turbos.
Old Mar 13, 2010 | 12:50 PM
YARO.'s Avatar
The compression shouldn't be a problem with a good tune. But the turbo I would upgrade.
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
civic-r11
Mar 31, 2009 12:04 PM
duck22krazy
Nov 12, 2008 11:59 PM
pcguy760
May 1, 2005 05:21 PM
s0liDyNe
Jul 19, 2003 10:24 PM
