compression test results and questions
Old Sep 5, 2007 | 02:11 PM
redlinetuning's Avatar
Default compression test results and questions
on a gsr (stroke and length are the same as stock), if je pistons are 9:1 ratio and the bore is 81.5mm with a stock chamber on the gsr head, does 150psi all across sound right to you?
I did some searches on google too but didn't really find anything. thanks.
Old Sep 5, 2007 | 02:27 PM
RC000E's Avatar
Default Re: compression test results and questions (redlinetuning)
I think 180 would sound better, but in general if all your cylinders are within 5% of each other or so then it's safe to say your good.
How many miles are on the motor? You can also do a leakdown if you want another perspective on cylinder seal.
Also, since your compression testing, is there a problem that is leading you to want to do this, or are you just compression testing out of curiosity?
Old Sep 5, 2007 | 02:34 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">on a gsr (stroke and length are the same as stock), if je pistons are 9:1 ratio and the bore is 81.5mm with a stock chamber on the gsr head, does 150psi all across sound right to you?
I did some searches on google too but didn't really find anything. thanks.</TD></TR></TABLE>
Are you doing the compression test after the motor is up to operating temp? Also while cranking have accelerator to the floor as well?
#s seem low BUT the important part is it is consistent across the board.
Old Sep 6, 2007 | 04:08 AM
Default Re: compression test results and questions (Boostfed.com)
actually a buddy of mine did the compression test. it's a turbocharged car he's interested in getting. he asked me and i wasn't sure why it was a bit low.
thanks for the answers. he did say he did the test before the engine was at operating temp ..
Old Sep 6, 2007 | 05:11 AM
dreadcivicturbo's Avatar
have you performed a valve adjustment on this motor
Old Sep 6, 2007 | 10:45 AM
A.E Motoring's Avatar
Default Re: (dreadcivicturbo)
how many cranks? do it over
Old Sep 6, 2007 | 11:02 AM
da_dude's Avatar
Sound about right since it was still cold when he did the compression.
Old Sep 6, 2007 | 11:37 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (turb20_vtec)
throttle open, 4-5 blips on the gauge.
if you are scared, put a drop of oil in the cylinder before and see if and how much it goes up. if it is significant, then the rings are done.
boostedteg4dr
Jan 24, 2009 03:52 PM
eg:R
Aug 8, 2008 02:58 PM
Nextelbuddy
May 9, 2005 07:42 PM
Quade
Apr 5, 2005 03:12 PM
B20luda
Jun 8, 2004 08:20 PM
