Compression Test Results
Old Sep 15, 2002 | 01:08 AM
Andrew 825SM's Avatar
Default Compression Test Results
I did a compression test on my B18C today and the numbers came up to be 180 across the board. This was on a warm engine and cranked the engine 6 revolutions. Do the numbers seem a little low because I have heard that the numbers are suppose to be around 210. Has the turbo wore out my cylinders?
[Modified by NHB Fighter, 2:15 AM 9/15/2002]
Old Sep 15, 2002 | 01:45 AM
ninesecrx's Avatar
Default Re: Compression Test Results (NHB Fighter)
It depends on the gauge...some have higher readings then others. sounds fine to me as they are all equal.
Old Sep 15, 2002 | 03:11 AM
rjardy's Avatar
whats your milage like?
Rob
Old Sep 15, 2002 | 03:36 AM
Cyber ITR's Avatar
Default Re: Compression Test Results (rjardy)
i used to have 210 , then took it to the drags ONCE for 4 runs
got home checked the compression and got 200
i lost 10psi *sigh*
turbo
Old Sep 15, 2002 | 10:30 AM
Default Re: Compression Test Results (VTEC_SiR)
i only have 16,500 on my motor
76 camaro car
Apr 20, 2017 04:47 AM
stockb18c
Oct 13, 2006 08:52 AM
John.
Jun 12, 2006 08:45 AM
snowblind7x
Apr 13, 2005 08:12 PM
InLimbo87
Jun 19, 2004 01:50 PM
