Compression test on a 9:1 forged engine - think it's bad!?
Old Mar 2, 2010 | 10:07 AM
DreTec's Avatar
Icon2 Compression test results on a 9:1 forged engine! Is my engine ok?
Alright guys,
Got back onto my project turbo B16. Its been sat a while feeling sorry for itself, but before getting started I thought I'd check how healthy it is, so done a compression test.
It's a B16 with CP 9:1 pistons.
On another thread in this forum I seen this:
per the evans tuning checklist:
8.5:1~9.5:1 compression: 170-210 psi per cylinder
The results I got were: 175 - 170 - 165 - 175
So they are lower than they should be and not the same! What does this mean and where should I go from here guys?
Old Mar 2, 2010 | 10:15 AM
Henryx33's Avatar
Default Re: Compression test on a 9:1 forged engine - think it's bad!?
It looks fine. Is the motor giving you any issues?
Old Mar 2, 2010 | 10:21 AM
DreTec's Avatar
Well it's hard to say, cos the turbo is shot. Buying a new one when I come over to Florida in April. But the engine is coming out anyway for me to clean it up, and flush the engine bay. So done the test now cos if somethings wrong I could sort it whilst it's out, but didn't wanna have to open up the engine if I could help it.
So the results I got were ok?
Old Mar 2, 2010 | 10:33 AM
tech_fan23's Avatar
New User
it's cool...i ran 9:1 CP pistons on a boosted motor for 4 years as a DD...and never had any problems
Old Mar 2, 2010 | 12:24 PM
DreTec's Avatar
^^ I'm not questioning how good a 9:1 forged build is... I'm questioning my compression test results. They are low and a not all cylinders results were the same.
Can anyone else confirm that my results are ok or should I be concerned? Thanks.
Old Mar 2, 2010 | 12:57 PM
hmoobhero's Avatar
looks fine to me. as long as they're 20psi within each other its good. how did you do the test?
Old Mar 2, 2010 | 01:02 PM
DreTec's Avatar
Cool! First time I done one to be honest. Figured I done it right. Plugs out, screwed in the comp tester, had a friend turn the engine over until the needle maxed out. The tester was also Snap-On so imagine the results were reliable. That's right yeah?
Old Mar 2, 2010 | 01:04 PM
d16z6Tcrx's Avatar
wide open throttle and fuel cut?
Old Mar 2, 2010 | 01:06 PM
DreTec's Avatar
No, literally just turned it over. DOH! I take it this means my results aren't accurate!
Old Mar 2, 2010 | 01:11 PM
perseverance's Avatar
you have to disconnect the injectors. i usually just unplug the fuel pump fuse and run it til it dies. then i do the compression test.
Old Mar 2, 2010 | 01:12 PM
DreTec's Avatar
And I have to do the compression test full throttle yeah?
Old Mar 2, 2010 | 01:18 PM
da_dude's Avatar
Always do it at full throttle and motor warm.
Old Mar 2, 2010 | 01:19 PM
DreTec's Avatar
Ok, thanks alot guys!!
Will do it tomorrow and post my new results. I'm in the UK and it's 11pm so bit late now.
Old Mar 3, 2010 | 09:08 AM
DreTec's Avatar
Thanks for pointing me in the right direction guys, after doing the test PROPERLY I got some great new results: 185 - 180 - 180 - 185
Old Mar 3, 2010 | 10:21 AM
kyden's Avatar
then you're good to go.
dkboyny11
Sep 20, 2006 03:56 PM
dkboyny11
Sep 12, 2006 04:49 PM
1FastCoupe
Apr 13, 2005 09:31 PM
B20luda
Jun 8, 2004 08:20 PM
avex
Apr 23, 2004 08:34 AM
