compression results
Old Aug 11, 2002 | 02:55 PM
geminis2k's Avatar
Default compression results
I did a test today at a buddy's house, I got the following results.
Cy 1 - 117
Cy 2 - 120
Cy 3 - 117
Cy 4 - 117
Now, these numbers are low - obviously - I was heart broken when I read other peoples results but started to see how they tested it to begin with.
My friend insisted on letting the car sit for 3 hours to "cool" down. From what I read most people run it warm. We only cranked it 3x, from what I read most people crank it 5-7. It was not wide open throttle as well.
Should I just take it to a shop and get it tested or should I just assume had we done it like most my numbers would be what most people get. Everyone says as long as the numbers are the same across the board I should be fine. Keep in mind I plan on rebuilding the engine regardless, but it would be a month after I get my turbo installed.
[Modified by deception23, 1:53 AM 8/12/2002]
Old Aug 11, 2002 | 04:45 PM
CovertFI's Avatar
Default Re: compression results (deception23)
well you should do it warm. and i get good results even with the tb closed
Old Aug 11, 2002 | 05:05 PM
Mase's Avatar
try it WOT, cuz when i did it....i got 175 across the board closed throttle, and then 210 across the board WOT....it might be a big difference
Old Aug 11, 2002 | 06:41 PM
CovertFI's Avatar
Default Re: compression results (CDooMe2)
well bottom line if they are really close that is good. i have never heard of a fucked motor have the same compression numbers.
caliEJ8
Jan 29, 2016 07:36 AM
rmrider12522
Mar 1, 2014 08:16 AM
umair
Dec 7, 2009 10:37 AM
lude98SH
Nov 12, 2005 06:21 PM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
