EG with b-series chargepipe/FMIC pipes fit EK with b-series?
New User
i need a quick answer and someone with first hand experience to answer this so i can get a kit.
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (93supercoupe)
The top charge pipe is different so you will have to get an EK one to replace the EG one.
New User
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">The top charge pipe is different so you will have to get an EK one to replace the EG one.</TD></TR></TABLE>
is the chargepipe longer/shorter, different angle, etc?
thanks
thanks
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (Unjockable)
only problem is if your EK is a non si or EX version. you dont have the hole for the intake right behind the headlight. if you do have this hole.t he piping should fit fine. if its a drag kit the piping isnt too much different and should work.
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">only problem is if your EK is a non si or EX version. you dont have the hole for the intake right behind the headlight. if you do have this hole.t he piping should fit fine. if its a drag kit the piping isnt too much different and should work. </TD></TR></TABLE>
drag piping doesn't go thru that lil hole
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (M.A.R.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. »</TD></TR><TR><TD CLASS="quote">
drag piping doesn't go thru that lil hole</TD></TR></TABLE>
Then it shouldn't matter of it's on an EK or EG. I'm running piping on my EG that was originally setup for a non-VTEC EK, had to trim a little but it works fine
Re: EG with b-series chargepipe/FMIC pipes fit EK with b-series? (VTC_resurected_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC »</TD></TR><TR><TD CLASS="quote">
Then it shouldn't matter of it's on an EK or EG. I'm running piping on my EG that was originally setup for a non-VTEC EK, had to trim a little but it works fine </TD></TR></TABLE>
yah... if it's setup for a non-vtec ek it should work fine in an EG. i had drag piping for an si on my d16 before
