Compression/leakdown test on my 2jz-ge
Old Apr 26, 2007 | 03:12 PM
garados's Avatar
Default Compression/leakdown test on my 2jz-ge
My 03 IS300 has been supercharged with a powerdyne bd11a at 7 psi and controlled by an e-manage for about 12k miles over ~4 years.
Lexus did a compression and leakdown test on my car. Here are the results ...
Compression/leakdown percentage
#1) 140/22
#2) 145/20
#3) 155/15
#4) 155/15
#5) 150/17
#6) 155/15
From my little knowledge on the subject, the compression looks ok because the span is only 15 psi which keeps it with ~10% (15 psi) variation from a rough average of ~150psi. What makes me worried is that I read that a stock engine should be putting about 190 psi, but then again, this test was done at ~5000' ASL (above sea level) and an unknown engine temperature.
Now the leakdown ... shouldn't it be down in the 5-10% range?
Thanks for the insight!
Old Apr 26, 2007 | 03:14 PM
SOHC_MShue's Avatar
Default Re: Compression/leakdown test on my 2jz-ge (garados)
the leakdown numbers look pretty high. Did you check to see where it was leaking from and do you burn oil?
Old Apr 26, 2007 | 03:45 PM
garados's Avatar
Default Re: Compression/leakdown test on my 2jz-ge (SOHC_MShue)
no burning oil ... and the Lexus techs didn't go too in depth with the test. The more I think about it, they probably didn't get the engine up to normal operating temperature before doing the tests.
76 camaro car
Apr 20, 2017 04:47 AM
Belarus
Apr 2, 2010 03:01 AM
Junkie
Mar 22, 2008 12:21 PM
Brad
Sep 8, 2006 02:13 PM
John.
Jun 12, 2006 08:45 AM
