comp. ratio with boost
Old Oct 31, 2004 | 10:09 PM
cxVtecC1's Avatar
Default comp. ratio with boost
is it possible to have a setup that makes power in the mid 9000 rpm range and still be able to run big boost or is this a bad chemical limit, opinions on valvetrain parts that would possibly be great for THIS setup i dont have the $$$$ for a bottom end build but have a b18b1 to start with iwant to stick with my bottom end for now
b18c1 w/ usdm itr pistons and the rest is stock would a block gaurd help and would high compression valves be a bad thing???????with boost before/after built bottomend
Old Oct 31, 2004 | 10:46 PM
cxVtecC1's Avatar
Default Re: comp. ratio with boost (cxVtecC1)
bump
Old Oct 31, 2004 | 10:47 PM
cxVtecC1's Avatar
correct me if im wrong its why i asked
Old Nov 1, 2004 | 04:19 AM
ogabudiah's Avatar
Forget building anything, stick with the ls motor you'll be happy. This isn't fast and furious you don't need 9000 rpm's.
Old Nov 1, 2004 | 05:30 AM
Bailhatch's Avatar
Default Re: comp. ratio with boost (ogabudiah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogabudiah &raquo;</TD></TR><TR><TD CLASS="quote">This isn't fast and furious </TD></TR></TABLE>
How dare you take away my dream
Old Nov 1, 2004 | 05:34 AM
mrspeaker's Avatar
Default Re: comp. ratio with boost (Bailhatch)
I know a guy with a stock ls motor with a t3-super 60 and he makes the most power at 5300-5500rpm.....no need for this 9000rpm BS.
JUANSTURBOTEG
May 18, 2007 06:43 PM
ludatic98
Mar 2, 2007 06:00 PM
one slow coupe
Mar 19, 2006 05:52 PM
-iLLuZioN-B18C1
Feb 20, 2004 07:24 AM
DanM
Apr 12, 2003 04:40 PM
