common turbo problems
im considering going turbo n i just wanna know wat the most frequent problems with them are
Re: common turbo problems (cleanej2)
With the turbo itself? Engine problems caused by turbo? Or both? The question is vague, what do you mean more specifically?
Re: common turbo problems (awdgsx96)
any kinda of problems at all.. thats why i made the question so vague
Ok....try a search for turbo (insert motor here ex. b16) or something to that nature, and see what problems you find. But off my head, there are:
- Not enough knowledge of how turbocharging work - Increased chance at detonation - Tuning problems - Finding correct exhaust for your setup - No support for boost, such as no upraded fuel or engine mangement - Improperly sized turbo for engine or application Hope I was some help |
problems are usually with the owner, not with the turbo setup itself...
being cheap is a big thing... not spending the proper money on a good tune.. Buying cheap parts to save some money, when you have to replace them in the long run anyways... Proper knowlege and research is key https://honda-tech.com/forums/images/smilies/emthup.gif you shouldnt be expected to know EVERYTHING, but there are some things you should know and understand before tackling the project... hope this helps... I bet anyone on here that has a boosted car can tell you things they would do better next time around... Ive had 3 different setups in my car now, each year.. and im learnin constantly... makin life easier in the long run |
