common oil leaks
Old Jun 21, 2006 | 10:12 AM
Akalima's Avatar
Default common oil leaks
Hey guys just trying to track down a oil leak in my car, So what are the common area's i.e. seals that leak on a b18c1 that is boosted.
Old Jun 21, 2006 | 11:14 AM
rtype11's Avatar
Default Re: common oil leaks (Akalima)
front main seal - from using heat to help loosen crank bolt, oil pan, cam seal
Old Jun 21, 2006 | 12:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: common oil leaks (rtype11)
valve covers. rear mains, cam seals, the spool valve housing, dist oring.
Old Jun 21, 2006 | 12:14 PM
coneheadsracing's Avatar
Default Re: common oil leaks (boostedcivicsir)
haha, i think you guys got every seal listed
Wheres your main oil at in the engine? Clean it up, take a short drive and try and narrow down where its coming from.
Old Jun 21, 2006 | 05:19 PM
Akalima's Avatar
Default Re: common oil leaks (coneheadsracing)
its almost looking like it coming from the pan or rear main in just seeps very little hits the axles and hits the cat and starts smonking.
Old Jun 21, 2006 | 05:59 PM
platinum00's Avatar
go to NAPA and by some additive for your oil. it glows in the dark and you can use a blacklight to track down the leak.
it works everytime
platinum.
Old Jun 21, 2006 | 06:16 PM
Akalima's Avatar
Default Re: common oil leaks (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">go to NAPA and by some additive for your oil. it glows in the dark and you can use a blacklight to track down the leak.
it works everytime
platinum.</TD></TR></TABLE>
no **** ive never heard of that thanks for the tip
Old Jun 21, 2006 | 06:59 PM
IN VTEC's Avatar
EX cam end plug.
Distributor o-ring.
Head gasket corners.
Those are the most common I've seen or experienced.
Old Jun 21, 2006 | 07:25 PM
stealthmode62's Avatar
it works everytime
WTF? lol.
Find the highest point of oil on the motor and there's your leak. I can't think of any two possibilities on the same side/height of the motor, so it shouldn't be too hard.
kornerk12
Oct 8, 2008 06:36 AM
Lauj87
Apr 4, 2007 07:50 PM
92civeg
Jan 26, 2006 07:59 PM
NerveAgent
May 27, 2005 06:09 PM
SKDRCR
Jul 2, 2004 02:27 PM
