comments/suggestions needed
Old May 7, 2005 | 04:30 PM
DFW's Avatar
DFW
Default comments/suggestions needed
Just picked up this block/head for $200. does it look like any damages to the crank/sleeves/head? i plan on getting a b16 head. Then for the bottom end, im just gunna use the stock sleeves but bore it out to 81.5, rollerwave pistons and eagle rods with the arp bolt upgrade. any comments/suggestions would be great
http://photos11.flickr.com/128...b.jpg
http://photos9.flickr.com/1283...b.jpg
http://photos10.flickr.com/128...b.jpg
Old May 7, 2005 | 05:46 PM
DFW's Avatar
DFW
Default Re: comments/suggestions needed (DFW)
Old May 7, 2005 | 06:54 PM
SSBPGSR's Avatar
nothing a quick bore/hone cant fix. get a closer pic of the crank. just look for scratches in it. also does the black have the mains still in it? did it come with the main cap/girdle? if so look at the bearings in them and see if there is any damage done. if you see coper run and hide
Old May 7, 2005 | 07:05 PM
DFW's Avatar
DFW
Default Re: comments/suggestions needed (SSBPGSR)
i know the crank could use some micropolishing, but yeah ill take pics of the rest of things.
Old May 7, 2005 | 07:22 PM
DFW's Avatar
DFW
Old May 7, 2005 | 07:40 PM
SSBPGSR's Avatar
i spy no bearings to inspect. so i guess your best bet would to bring the block/crank to the machine shop to get bored and honed/ micropolished. you got PM
Old May 7, 2005 | 10:22 PM
DFW's Avatar
DFW
Old May 8, 2005 | 01:48 AM
budget's Avatar
free bump so you can get an answer
Old May 8, 2005 | 02:06 AM
sik96teg's Avatar
Default Re: comments/suggestions needed (ratboy)
yea that looks like a good bit of rust in ur head
Old May 8, 2005 | 10:18 AM
DFW's Avatar
DFW
Default Re: comments/suggestions needed (sik96teg)
im not guna be using the head anyways...
Old May 8, 2005 | 06:07 PM
sik96teg's Avatar
you should be good to go then when i had my block bored and got it back they clean da **** out of it it looked brand new so you should be fine.
Old May 8, 2005 | 06:12 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik96teg &raquo;</TD></TR><TR><TD CLASS="quote">you should be good to go then when i had my block bored and got it back they clean da **** out of it it looked brand new so you should be fine.</TD></TR></TABLE>
what do you think about the rest of it?
Old May 8, 2005 | 06:41 PM
sik96teg's Avatar
dont know make sure u take the crank in with the block to get checked you never know. If your getting after market flywheel and crank pulley i would take those in to get chaeck all at the same time make sure everytings balanced
Old May 8, 2005 | 06:44 PM
sik96teg's Avatar
everything should come out ok your atleast smart enought to go 81.5 instead of say like some people "O i think i will be ok wit standard bore".
Old May 8, 2005 | 06:47 PM
DFW's Avatar
DFW
haha ite thanks for the help
but im might resleeve since im getting piston and rods and go for either 84 or 84.5mm...
Magicmo413
25
Jun 11, 2014 11:44 AM
Spawne32
May 21, 2010 06:29 PM
ST4TUS
Jan 13, 2007 05:51 AM
B18Redline
Jan 28, 2005 07:30 AM
baonest
Jul 26, 2002 02:41 AM
