comment on my compression please
i generally go by the rule if the high and low are within 20 something... then ur fine... what u look for in a compression test is not so much the numbers themselves and the u do the similarity of them
The numbers need to be both consistent and high.
You numbers are fine, they show a compression ratio close to 10:1 and they are within 15% of each other. So the rings are OK.
Randy
Randy
did u do the test when the motor was hot or cold? that also makes a differance...
and as was said before... its not so much how how they are... its the consistency
locote
Jan 8, 2007 03:30 PM
