comment on my compression please
Old Jun 22, 2002 | 04:58 AM
Cyber ITR's Avatar
Default comment on my compression please
190 200 190 205
stock jdm b18c
thanks
Old Jun 22, 2002 | 05:19 AM
TurboSohc's Avatar
Default Re: comment on my compression please (VTEC_SiR)
good numbers
Old Jun 22, 2002 | 05:20 AM
TurboSedan's Avatar
New User
Default Re: comment on my compression please (TurboSohc)
Those numbers look fine, be worried if one or more of them drop very low. For example 190 200 120 205.
Old Jun 22, 2002 | 07:43 AM
bigTom's Avatar
Default Re: comment on my compression please (97CivicFerio)
i generally go by the rule if the high and low are within 20 something... then ur fine... what u look for in a compression test is not so much the numbers themselves and the u do the similarity of them
Old Jun 27, 2002 | 03:37 AM
Cyber ITR's Avatar
Default Re: comment on my compression please (ek9t)
arent they a lil bit low for B18C ??
im worried
Old Jun 27, 2002 | 04:05 AM
TurboSedan's Avatar
New User
It is more important that the numbers are consistent, rather than high.
Old Jun 27, 2002 | 04:18 AM
RGAZ's Avatar
New User
The numbers need to be both consistent and high.
You numbers are fine, they show a compression ratio close to 10:1 and they are within 15% of each other. So the rings are OK.
Randy
Old Jun 27, 2002 | 04:30 AM
Cyber ITR's Avatar
Default Re: comment on my compression please (RGAZ)
stock JDM B18C i believe 10.6:1 , so the rings are worn a lil bit already ???
Old Jun 27, 2002 | 12:04 PM
bigTom's Avatar
did u do the test when the motor was hot or cold? that also makes a differance...
and as was said before... its not so much how how they are... its the consistency
Old Jun 27, 2002 | 06:00 PM
Cyber ITR's Avatar
hot , WOT
97EXB18C
May 23, 2009 11:08 PM
gursh d
Jul 7, 2007 06:18 PM
stockb18c
Oct 13, 2006 08:52 AM
Mugen112
Dec 28, 2005 12:48 AM
