Cometic or no Cometic
Old Jun 8, 2007 | 05:47 PM
  #26
ej8's Avatar
ej8
Default Re: (ProPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProPerformance &raquo;</TD></TR><TR><TD CLASS="quote">I will check the surface of the head this weekend at the the shop.ERL done the block it looked good.</TD></TR></TABLE>
ERL sent out a couple of block with sunken sleeves, my friend got one of them so I would check the deck surface too
Old Jun 8, 2007 | 07:33 PM
  #27
Mr HYDE's Avatar
Default Re: (Golden Eagle)
i blew 3 cometic headgaskets in one year then switched to GE modded OEM gasket and have had no problems
Old Jun 11, 2007 | 03:24 PM
  #28
masterbuilder's Avatar
Default Re: (Mr HYDE)
same here
Old Jun 11, 2007 | 03:41 PM
  #29
mike93eh2's Avatar
oem with hylomar here.
Old Jun 12, 2007 | 03:39 PM
  #30
Boostfed's Avatar
New User
I am about to put my 84mm sleeved block together with a decent size turbo and goood ported head and I am using a Cometic gasket, OH NOOOOOOOOOOOOOOOOOOOOOOO I am gonna have problems, what do I do? Cometics suck because some H-T users said so.... lol Sarcasm is a great thing
Old Jun 12, 2007 | 03:47 PM
  #31
mike93eh2's Avatar
cometic sucks because they are no better than oem unless you are looking for a thicker headgasket to get the compression ratio down. but then again i would be doing other things to get it down.
Old Jun 12, 2007 | 06:11 PM
  #32
ladysman's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">cometic sucks because they are no better than oem unless you are looking for a thicker headgasket to get the compression ratio down. but then again i would be doing other things to get it down.</TD></TR></TABLE>
Or if you have a big bore D series and have no choice but cometic.
Old Jun 12, 2007 | 06:14 PM
  #33
Boostfed's Avatar
New User
Never ever said they were better BUT they are no worse either! The OEM gaskets DO fit better, over the dowel pins and when installing it on a motor with headstuds, OEM just slides down and all is good
I am just saying people need to stop saying Cometic is crap, they work and work well, you are not gonna gain horsepower from the gasket so.....
Old Jun 12, 2007 | 06:20 PM
  #34
ladysman's Avatar
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
you are not gonna gain horsepower from the gasket so.....</TD></TR></TABLE>
How do you know? lol
APC needs to come out with some switchable glow gasket thing. I'd buy it for my daily driver.
Old Jun 12, 2007 | 06:30 PM
  #35
mike93eh2's Avatar
Default Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
no, there is GE.
Old Jun 12, 2007 | 06:31 PM
  #36
mike93eh2's Avatar
I am just saying people need to stop saying Cometic is crap, they work and work well, you are not gonna gain horsepower from the gasket so.....</TD></TR></TABLE>
yes they are worse.. in the money department. oem baby!!!!!
Old Jun 12, 2007 | 07:14 PM
  #37
Boostfed's Avatar
New User
yes they are worse.. in the money department. oem baby!!!!!</TD></TR></TABLE>
So I needed an 85mm bore .040" thick, so how is OEM gonna help me? What other ways can I get a thicker gasket? Or what is the proper way of doing this again?
Old Jun 12, 2007 | 08:00 PM
  #38
mike93eh2's Avatar
So I needed an 85mm bore .040" thick, so how is OEM gonna help me? What other ways can I get a thicker gasket? Or what is the proper way of doing this again? </TD></TR></TABLE>
and i quote..
not trying to argue but if you are able to use a oem gasket then use it if not then use cometic.
edit: arent oem gaskets .037" ? thats not much difference from .040"
Old Jun 12, 2007 | 08:11 PM
  #39
Boostfed's Avatar
New User
and i quote..
edit: arent oem gaskets .037" ? thats not much difference from .040"</TD></TR></TABLE>
Stock gaskets are .029" and yes if I had a choice of OEM VS Cometic I choose OEM FIRST due to fitment is better and more precise BUT again their is still nothing wrong with a Cometic gasket though. As I mentioned lining up with dowel pins and installing with headstuds can be a pita but it works is all . Dude we could go back and forth adn keep going and make this the longest most worthless thread on H-T if we wanted.
All I wa stating is the people bashing Cometic and stating they are junk and will have problems is straight BS
Old Jun 12, 2007 | 08:17 PM
  #40
mike93eh2's Avatar
well i know d-series are .037" compressed
Modified by mike93eh2 at 9:29 PM 6/12/2007
Old Jun 12, 2007 | 08:21 PM
  #41
ladysman's Avatar
no, there is GE. </TD></TR></TABLE>
Not when my motor was put together.
Old Jun 13, 2007 | 12:52 PM
  #42
Golden Eagle's Avatar
</TD></TR></TABLE> we have ben doing d sires gaskets for years now
Old Jun 13, 2007 | 12:56 PM
  #43
HamiltonRex's Avatar
i run OEM now, no problems, had problems with cometic.
Old Jun 13, 2007 | 01:16 PM
  #44
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> we have ben doing d sires gaskets for years now </TD></TR></TABLE>
it's been 4 years +. Probably longer.
I can remember calling you guys and it was noted that you were only doing D series. Good to see that has changed although I haven't had a reason to take my cometic out....yet.
Old Jun 13, 2007 | 01:19 PM
  #45
tony1's Avatar
Default Re: (HamiltonRex)
We used to have a lot of problems with headgaskets on Chuck's car, when he first started running it. Switched to GE/OEM and no more problems. I don't know enough about head gaskets to know why the oem works better, but from my experience, it definitely does work better.
Old Jun 14, 2007 | 04:11 PM
  #46
Boostfed's Avatar
New User
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We used to have a lot of problems with headgaskets on Chuck's car, when he first started running it. Switched to GE/OEM and no more problems. I don't know enough about head gaskets to know why the oem works better, but from my experience, it definitely does work better.</TD></TR></TABLE>
So Tony what did you end up running on that one customer's car that ordered the GE LS/VTEC kit from me and GE sends the VTEC gasket with it. Didn't you and Art just get a Cometic for him? Is it just Chuck that has had issues with the Cometics? Seriously curious
Old Jun 14, 2007 | 04:33 PM
  #47
tony1's Avatar
We used a stock B20 gasket on it...
Old Jun 14, 2007 | 04:35 PM
  #48
Boostfed's Avatar
New User
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We used a stock B20 gasket on it...</TD></TR></TABLE>
Gotcha. I put my Cometic on today, again like I said before they do suck trying to get them over the damned dowel pins. You would think they would have bored that out more by now. This one actually fit very well except the dowels was super tight as always . We shall see when we fire her up next week and get some track time soon.
Old Jun 15, 2007 | 08:03 AM
  #49
the difference from cometic and oem honda is the cometic uses a galvanized center layer and honda is stainless center layer we all know stainless is stronger, i know many people use cometic gaskets with no problems but we never had any luck with them and do not care for them. as for the vtec kit we sell at least 50 a week all using the vtec gaskets with no problems
Old Jun 15, 2007 | 01:50 PM
  #50
N.Y.C.E.'s Avatar
i never had any luck with the cometic gaskets, the fire ring in the middle always blew, oem never gave me any problem
