Coldest Plugs Available ?
Old Jan 19, 2006 | 02:30 PM
integlspwr2k's Avatar
Default Coldest Plugs Available ?
I need some NGK part numbers for the coldest spark plug available that will fit a B16 Turbo motor.
Thanks In Advance.
Old Jan 19, 2006 | 06:21 PM
Default Re: Coldest Plugs Available ? (integlspwr2k)
Old Jan 19, 2006 | 07:06 PM
Pullig's Avatar
http://www.ngksparkplugs.com/i...a0000
Modified by Pullig at 1:13 AM 1/20/2006
Old Jan 20, 2006 | 04:15 AM
Default Re: Coldest Plugs Available ? (Pullig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.ngksparkplugs.com/i...a0000
Modified by Pullig at 1:13 AM 1/20/2006</TD></TR></TABLE>
the coldest i found was..
BKR9E
any colder?
Old Jan 20, 2006 | 04:19 AM
PrecisionH23a's Avatar
How much power are you looking at making? I know a lot of guys that hit over the 700 range use the 9's.
Old Jan 20, 2006 | 04:20 AM
Default Re: Coldest Plugs Available ? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">How much power are you looking at making? I know a lot of guys that hit over the 700 range use the 9's.</TD></TR></TABLE>
i just want coldest for peice of mind...
i know people have used 9' with 700whp, but i rather use 11's if i can find part numbers.
so any help is appricated.
thnx.
Old Jan 20, 2006 | 04:22 AM
Get the 9's and put them in a freezer. Honestly, colder is not always better.
Old Jan 20, 2006 | 04:41 AM
seen4ever's Avatar
i assume this car isn't going to be a street car then? as 11s will definately foul out. Plus going with that cold of a plug, you are going to have issues getting a good burn. I'd just recommend finding the plug with the best burn pattern in your engine.
Old Jan 20, 2006 | 07:15 AM
turbotime's Avatar
7's !
Old Jan 20, 2006 | 10:29 AM
Old Jan 20, 2006 | 10:45 AM
tony1's Avatar
You don't want the coldest plug you can find...
Old Jan 20, 2006 | 10:51 AM
Default Re: Coldest Plugs Available ? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You don't want the coldest plug you can find...</TD></TR></TABLE>
i actually found some..
R5671A-8 [NGK-4554]
R5671a-9 (NGK5238)
R5671A-10 (NGK-5820)
BKR9E
Thanks guys...
Old Jan 20, 2006 | 11:16 AM
seen4ever's Avatar
i run the 8s in my engine right now, but it never really is below the 400whp mark. for next year i may throw in 9s when i start to spray it, but all depends on what the ground strap says.
Old Jan 20, 2006 | 04:13 PM
SOHC_MShue's Avatar
just run 8's or 9's. How much power are you trying to make?
Old Jan 20, 2006 | 04:24 PM
jpenman50's Avatar
Why not?
Old Jan 20, 2006 | 07:32 PM
JDM_Risa's Avatar
Default Re: Coldest Plugs Available ? (jpenman50)
any idea what kind of plugs i shud run sorrie for off topic... i am running a Type R motor with 10:1 c/r forged rods and piston...making 366whp@15psi as of now planning on going closer to 400whp...i am running 3 step colder plugs...
Old Jan 20, 2006 | 08:16 PM
Toda Party's Avatar
Default Re: Coldest Plugs Available ? (JDM_Risa)
what plugs are u using for 8 and 9 temps? and how much?
i had some trouble finding a regular old 8 or 9 temp plug like the BCP or BKRE-7...so cheap too...i had to use 5 dollar a plug 8 temp iridium cuz i sucked
Old Jan 21, 2006 | 02:29 AM
Default Re: Coldest Plugs Available ? (Toda Party)
most people CAN get away with a 7, but why can you get a 7 when you can get 8, 9s and even 10s.
Old Jan 21, 2006 | 07:49 AM
Drag_On's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">most people CAN get away with a 7, but why can you get a 7 when you can get 8, 9s and even 10s.</TD></TR></TABLE>
Doesn't work that way man.. there is a difference in being "safe" and being stupid. You are walking the line.
You don't want the coldest pulgs available and for your set up - you wont want an 11 range plug. 8s or 9s will be PLENTY for the build you have.. 11s are going to caude problems with fouling out and not getting a full burn from the plug
Old Jan 21, 2006 | 08:02 AM
BoostedEG6's Avatar
Default Re: Coldest Plugs Available ? (Drag_On)
edger you suck hahaha j/k just go with the 9's....... call me when you get this!!!!! you never called me the other day hahaha fawker
Old Jan 21, 2006 | 10:33 AM
Default Re: Coldest Plugs Available ? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">edger you suck hahaha j/k just go with the 9's....... call me when you get this!!!!! you never called me the other day hahaha fawker </TD></TR></TABLE>
sorry man i was just too intimiated to call you because your soo ****** hawt. you sexy white boi.
racerx023
Jun 26, 2006 06:52 PM
1.8
Jan 13, 2005 07:34 PM
JICB16B
44
Sep 26, 2003 07:34 AM
Vtec92Civic
Aug 23, 2003 07:00 AM
bottlefedb18c1
Jul 26, 2003 07:15 AM
