cold start problem
Old Dec 23, 2007 | 02:52 PM
firstclassjdm's Avatar
Default cold start problem
anyone know how i can cure this issue? as it got colder (below 40 degrees) here in wisconsin, i have trouble starting my car. it cranks over, but does not start. sometimes it takes 20-30 minutes to get car started. is it an ignition problem or tuning issue?
Here's my set up:
ENGINE
Stock Type R head and valvetrain (51k miles)
2.0L 84.5mm bore built by Import Builders (2500 miles)
Golden Eagle sleeves
9:1 compression Weiseco pistons
IB spec rods with ARP rod bolts
GE 84.5mm head gasket
GE Turbo oil feed kit
GE vacuum manifold
Edlebrock IM
Hasport motor mounts
Thermal 3" exhaust
TURBO
Full Race Stage 3 Turbo kit (T3/T67)
Full Race Traction bars
Turbo XS dual boost controller
Greddy turbo timer
ENGINE MANAGEMENT
AEM Engine Management System
AEM Fuel rail
AEM Fuel Pressure Regulator
AEM Fuel filter
AEM air/fuel ratio gauge
IGNITION/FUEL/ETC...
MSD Digital 6 with cap, wires, and blaster
RC 1000cc P/H injectors
Walbro 255
PWR radiator
Old Dec 23, 2007 | 02:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: cold start problem (firstclassjdm)
setup?
Old Dec 23, 2007 | 02:59 PM
Default Re: cold start problem (boostedcivicsir)
just edited post. please see above.
Thanks
Old Dec 23, 2007 | 05:17 PM
sander's Avatar
2.7(p/t)
Some of the AEM cold start corrections take some effort to get correct in ALL temp circumstances. I would ask your tuner to maybe glance at your cold start tables and make sure every thing is cool.
Old Dec 23, 2007 | 05:20 PM
boosstboy's Avatar
Default Re: cold start problem (sander)
hahahah, i feel your pain. i went through last winter with my aem. adjust your iat table and your coolant temp table's. my car would start only sometimes it was way to rich when very cold.
Old Dec 25, 2007 | 08:57 AM
Default Re: cold start problem (boosstboy)
thanks guys. i'll have to take care of that in the spring. car is being stored right now due to snow/winter.
thanks again.
Old Dec 25, 2007 | 09:14 AM
arc_55's Avatar
In these cold weather conditions it takes much more fuel to be injected because the fuel cannot atomize as easily. This is why the car will hicup usually if you try and take it leaner then 13.0-13.5 , but other cars it may vary slighty based on the characteristics. However Long cranks would indicate that your cranking fuel is not rich enough. I am sure you might be experiencing maybe a little bit of both. You can't blame the tuner as he cannot tune for these conditions perfectly unless he sees your car in these temps and cold start situations. Sometimes its adjusted blind eye and you can get it fairly well but other times it takes some touch up.
Old Dec 25, 2007 | 09:20 AM
boosstboy's Avatar
Default Re: cold start problem (arc_55)
mine was fuel because i didn't calculate my percentage change on the temp tables so when i turned the key on and the temp was reading 20 f outside it was dumping fuel causing fuel flooding, causing a no start. it helped when i gave it a little throttle because your allowing more air in to lean out the mixture slightly, but i think rule of thumb is for every 10 degrees cooler add 2% and subtract 2% for every 10 dgrees hotter away from base tune temp.
Old Dec 25, 2007 | 10:46 AM
Lmgrcivic's Avatar
I have this same problem I havent made it back to the tunner yet to change it. but it sucks when its cold outside and it takes you 20 mins to get the car to start
Old Dec 30, 2007 | 09:01 AM
Default Re: cold start problem (Lmgrcivic)
tell me about it. I hate it. I don't blame the tuner. It's expected on modified cars. I always have to hold the gas throttle down slightly to start the car...warm or cold conditions. My tuner put in a base map, but I have not had the chance to have him give the car a nice street tune. I think it's running rich when I crank it. No lie, once my car was running very low on gas, almost to the E mark. As I was trying to crank the car in the cold, after about 20 tries, I can see the needle move across the E mark. Needless to say, I had to go buy 2 gallons of gas to put in the car.
90turbosi
Feb 6, 2008 06:40 PM
slvrstns2000
Feb 22, 2006 02:48 PM
turbotk
May 28, 2004 07:33 PM
(__________)
Aug 27, 2002 09:56 PM
