cold air intake on turbo
Old Apr 21, 2004 | 02:05 PM
Nigel379's Avatar
Default cold air intake on turbo
Would a cold air intake be overkill on a turbo'd car? With an intercooler is a cai just a waste or even worth it? Would it hurt performance because of the longer intake pipe? By the way I own a Mazda 323 GTX...rare and fun car. Thanks
Old Apr 21, 2004 | 02:26 PM
Hriday's Avatar
Default Re: cold air intake on turbo (Nigel379)
Yes a cold air intake will help your performance. The lower the temp of the air the turbo is getting, the less you'll have to cool it afterwards. The turbo will also no longer be sucking in the warm air in the engine bay, which is allways a good thing. Remember that the cooler you keep the air the better.
Coincidentally I also have a 323GTX.
Old Apr 21, 2004 | 04:02 PM
bottlefedb18c1's Avatar
It will help alot
there is alot of under hood tems and if you can get the plumming out of that you should notice a differance due to the cooler air
Old Apr 21, 2004 | 05:03 PM
Nigel379's Avatar
Default Re: (bottlefedb18c1)
Thanks, anyone else have imput.
Old Apr 21, 2004 | 06:02 PM
vtec69's Avatar
Default Re: (Nigel379)
i/ve heard with the wrx that a cold air intake will cause you to run lean
not sure if its true or not but so i hear
-Brian
Old Apr 21, 2004 | 06:11 PM
project dc2's Avatar
Default Re: (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">i/ve heard with the wrx that a cold air intake will cause you to run lean
-Brian</TD></TR></TABLE>
its true, its cuz they use a mass air flow sensor.
Old Apr 22, 2004 | 05:19 PM
Nigel379's Avatar
Default Re: (project dc2)
Does that apply to all mass air flow sensor cars? My 88 323 GTX is Mass Air Flow Sensor. Thanks
Old Apr 22, 2004 | 05:24 PM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
its true, its cuz they use a mass air flow sensor. </TD></TR></TABLE>
This is like, way wrong.
Mass air flow and speed density cars both will fully compensate for any changes in air temperature.
Old Apr 28, 2004 | 03:48 PM
Nigel379's Avatar
Default Re: (kpt4321)
Any other oppinions? Thanks
Old Apr 28, 2004 | 03:57 PM
sneakypete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
Mass air flow and speed density cars both will fully compensate for any changes in air temperature.</TD></TR></TABLE>
This is true.
'93ludeboy
Dec 9, 2012 02:17 PM
threenuts84
Aug 28, 2007 05:56 PM
russian_racer
50
May 2, 2003 12:37 PM
turb
Jan 24, 2003 11:41 AM
not so civic
Jul 2, 2001 01:49 PM
