Pressure test questions.
Old Oct 16, 2013 | 09:41 AM
Snailor Built's Avatar
Default Pressure test questions.
I'm doing clean up on my car after the dyno. I need to pressure test my intercooler kit, and such. I'm using a forward facing manifold, so my question is, can I get a 4" cap and put it right on the front of the compressor of the turbo, the open part? Then just run like 50 psi through the entire system like that?
Old Oct 16, 2013 | 10:21 AM
ballistic1350's Avatar
Default Re: Pressure test questions.
pretty much... start low and slowly build up from there. I don't think you'll need to go that high though, you should catch a leak way before that pressure
personnaly I'd get a 4" coupler and then a pvc cap that fits in the other end.
Old Oct 16, 2013 | 10:27 AM
I would get some way of accurately monitoring pressure (gauge) and some way of limiting the rate you presurize (some kind of valve)
fyi things will blow off at high pressures be careful
Old Oct 16, 2013 | 01:37 PM
Tippyman's Avatar
If only someone showed you a set of instructions in how to do this in another thread... :p
Old Oct 16, 2013 | 07:39 PM
ricetastic's Avatar
yea..deff not 50 psi lol.. just put in short bursts and u will hear a leak if u have one
sdubfid
Welding / Fabrication
Nov 2, 2009 03:27 AM
civickid03
Apr 12, 2007 11:27 AM
1accord
Oct 1, 2006 11:20 PM
EFSiR
Apr 1, 2005 03:15 PM
B18EG6
Dec 15, 2004 08:42 AM
