CODE 7: TPS....Please HELP
Old Jul 19, 2001 | 10:11 AM
Evil DOHC's Avatar
Default CODE 7: TPS....Please HELP
Here is the cituation,
97 LS equiped with drag III kit. The car is getting a code 7, wich is the TPS sensor. Also, the car will lean out a little on top at 100% throttle at 4-5 psi. Can the TPS sensor be bad? Any input would be greatly appreciated.
EVIL
Old Jul 19, 2001 | 10:17 AM
redline's Avatar
Default Re: CODE 7: TPS....Please HELP (Evil GS-R)
I would say that TPS is bad if it is throwing a code
k
Old Jul 19, 2001 | 11:11 AM
Evil DOHC's Avatar
Default Re: CODE 7: TPS....Please HELP (redline)
I know there is something obviously wrong. We have tried two diff. ITB's and thesame error poped up on the ecu. Does anybody ever had one of these sensor's gone bad?
EVIL
Old Jul 19, 2001 | 12:12 PM
GSRwBOOST's Avatar
wonder if that's my problem.. im' leaning out above 5k and last week threw two codes.. and the car went crazy idle at a stoplight.. resetting the ecu cleared it up.. and occasionally i get a "surge"ing effect at a constant speed...
any way to test the tps?
Old Jul 19, 2001 | 12:26 PM
Evil DOHC's Avatar
Default Re: CODE 7: TPS....Please HELP (GSRwBOOST)
The only way I know to test the TPS is with a volt meter, and we have done that. But we dont' know what the initial readings should be. DOES ANYBODY HAVE THE ACURA BOOK SO THEY CAN LOOK IT UP FOR US? (TPS VOLTAGE READINGS)
Thanks,
EVIL
Old Jul 19, 2001 | 05:59 PM
FAST94GSR's Avatar
New User
do u have a vafc by any chance you can read the diagnostics on the tps from there. in any case i believe voltage should be around 1.2 v correct me if i'm wrong
Old Jul 19, 2001 | 06:45 PM
G's Avatar
G
Default Re: CODE 7: TPS....Please HELP (FAST94GSR)
I believe the voltage at closed throttle should be @ .40 - .50 volts and 4.5 volts at WOT. I saw someone mentioned ITB in an above post. Is that an individual throttle body, or just the stock. Either way, moving the tps to alter the voltage will have the above mentioned effects on the engine, sloppy idle and or leaning up top.
Old Jul 19, 2001 | 08:54 PM
dragnGSR's Avatar
I had this problem not too long ago with my TPS sensor. I would accelerate to a certain rpm and then a violent jerking motion would occur....then the car would throw a CEL. I come to find out that it was corrosion in one of the wires in the TPS. I couldn't see it myself but my mechanic found it when he took off my SC.
Old Jul 19, 2001 | 08:55 PM
redline's Avatar
Default Re: CODE 7: TPS....Please HELP (G)
that is the right voltage but at idle the voltage should be as close to .5 volts as you can get it.
if the voltage is out a little try hitting it with a screw driver.
that is it for now typing on this iPAQ with cdpd modem is a pain.
k
Old Jul 20, 2001 | 04:51 AM
Evil DOHC's Avatar
This LS has a stock throttle body with the stock TPS. We do have a AFC in the car, wich I can look at the voltage readings in the (ECT.) section. We shall look and see, what happens.
EVIL
Old Jul 20, 2001 | 01:03 PM
Batoutahell's Avatar
Default Re: CODE 7: TPS....Please HELP (dragnGSR)
dragnGSR: Which wire was corroded? I'm throwing the same CEL (code 7) with the same symptoms (car jerks back & forth and rough idle). Whenever I think I've narrowed it down to a faulty wire, the car miraculously, and temporarily, cures itself. I think my ground wire between the TPS plug and the IAT sensor is bad, but that's just my best guess. Checking voltages and continuity of the wires isn't too difficult, but it's tough to measure resistances at the TPS itself b/c of the awkward position. I'd be interested to hear everyone's overall consensus about what's causing the problem. Bad TPS? Bad wiring?
Old Jul 23, 2001 | 01:44 PM
Smashback's Avatar
Default Re: CODE 7: TPS....Please HELP (Batoutahell)
Yeah, I just installed a BBK throttle body on mine and I think the TPS is giving me some crap. Same deal as you guys..funky idle, jerking sometimes when I gun it. Sure does look good though, especially with that nice shiny Missing Link up top!
Old Jul 23, 2001 | 01:56 PM
dbman96's Avatar
New User
Default Re: CODE 7: TPS....Please HELP (mplex2000)
Since everyone is thinking about TPS readings, I just put a V-AFC on my GSR and I'm getting a very very rapid fluctuation of my TPS reading at idle - from around .45 to .65, but flashing back and forth faster than I can even read it. Is this a sign of a bad connection or bad sensor?
Old Jul 23, 2001 | 02:04 PM
dragnGSR's Avatar
I'm not exactly sure which wire it was since my mechanic found it. He just told me he found out the problem and fixed it. I know what you're talking about...it only occured sometimes.
Old Jul 23, 2001 | 03:35 PM
dragnGSR: If you think about it, next time you talk to your mechanic, would you ask which wire was bad? There's nothing worse than trying to trace a faulty wire in those microscopic wire harnesses that they put in our cars.
dbman96: I think your readings are still within spec. I need to doublecheck helms, but I'm pretty sure you're ok.
Old Jul 23, 2001 | 06:01 PM
dragnGSR's Avatar
I'll be sure to do that the next time I speak with him. If I get a chance tomorrow, I might check it out myself.
Old Jan 28, 2004 | 04:37 PM
JHD_DA's Avatar
im getting the same code as all of u. people say my tps is bad but i cant take it off of my TB. looks like it was rivited on or something. i dont get any crazy jerking on wot or anything but i think im leaning out and my idel stays at 1K. so ill probably just look for a new TB since i cant change my TPS.
Old Jan 28, 2004 | 04:41 PM
nsxmatt's Avatar
Default Re: (JHD_DA)
Take the TB off, get a dremel with a cut off wheel. Cut a slit in the rivet so you can fit a straight edge screwdriver in it and remove it. Then install with normal screws.
Old Jan 28, 2004 | 04:44 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (nsxmatt)
this happend to me in the middle of a race. either it's a bad sensor or wires are lose. My wire's had been cut when the guy before me ran a zex kit on the car. he needed to use the tps sensor. After a 2 years it eventually broke....the wiring that is. I soldered the wires together and haven't had a problem since.
streetsold6teeny8
Mar 24, 2012 06:46 PM
Walshie
11
Dec 1, 2006 01:42 PM
shabam
Oct 23, 2006 08:31 AM
VTECth1s
Aug 5, 2006 03:44 PM
skiracer8148
Aug 2, 2006 03:26 AM
