code 5 with boost >>
Old Jul 24, 2003 | 08:01 AM
platinum00's Avatar
Default code 5 with boost >>
every once and a while i get a code 5 cel.
MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping.
piping to map is hooked up correct and not leaking. does this mean my map is bad.
how does the ecu determine that it's a mechanical problem. from a invallid reading or somthing..??
platinum.
Old Jul 24, 2003 | 03:50 PM
platinum00's Avatar
Default Re: code 5 with boost >> (platinum00)
ttt
Old Jul 24, 2003 | 05:19 PM
Adub33's Avatar
The map sensor puts out a voltage. You are usually able to boost around 10-11 pounds on a stock map sensor without it throwing a code. You could try using check valves inline with your map sensor.
Old Jul 24, 2003 | 05:22 PM
platinum00's Avatar
Default Re: code 5 with boost >> (Adub33)
i get this boosting at 7..
i believe is a code 3 if you over boost you map.
i think..
Old Jul 24, 2003 | 05:25 PM
intekragsr's Avatar
you need a missing link or check valves
Old Jul 24, 2003 | 05:26 PM
platinum00's Avatar
Default Re: code 5 with boost >> (intekragsr)
why.
im not going over 10 psi.
Old Jul 24, 2003 | 05:38 PM
psileepR's Avatar
New User
wierd to get that code at only 7psi... maybe a bad map sensor ... those things are so finicky.
see if its a loose connector or something. the only code ive been getting is 13... damn obd2
Old Jul 24, 2003 | 05:41 PM
platinum00's Avatar
Default Re: code 5 with boost >> (psileepR)
yea obd 2 blows.
im switching to obd 1 real soon.(hondata) hopefully.. you think that might fix it.
if i gotta replace the map. you think i should just get a 3 bar.
Old Jul 24, 2003 | 09:12 PM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">why.
im not going over 10 psi. </TD></TR></TABLE>
because honda map sensors are not supposed to read boost. unless you have a 3 bar map sensor, you need check valves or missing link.
Old Jul 24, 2003 | 09:30 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">
because honda map sensors are not supposed to read boost. unless you have a 3 bar map sensor, you need check valves or missing link. </TD></TR></TABLE>
sorry i dont think thats it. i run 8psi daily with the afc hack and the only code i get is 13 which is the barometric sensor.
i dont get the code 5 he is getting.
lastly with the afc hack the map sensor never goes over 5 volts (so the ecu doesnt see boost) because we are trimming the map signal/fuel. its not until somwhere over 11psi does the afc hack not able to trim the map signal enough and the ecu reads boost.
Old Jul 24, 2003 | 09:54 PM
T4eg's Avatar
you need a missing link or check valves in line with the map sensor. That would take care of the problem
Old Jul 25, 2003 | 04:27 AM
platinum00's Avatar
Default Re: code 5 with boost >> (BlueHatch00)
the honda map actually does read boost just fine to ~10.65psi it's the ecu that does not like it, there are no boost fuel maps.
im taking care of that with the vafc hack thus eliminating the need for check valves and mising links.
that's for the help guys. any other idea's
Old Jul 25, 2003 | 06:58 AM
Full-Race Geoff's Avatar
your settings are off on the AFC, take some more fuel out
Old Jul 25, 2003 | 07:16 AM
platinum00's Avatar
Default Re: code 5 with boost >> (FFgeoff)
what are you guys runing your settings at for 10-11psi
also, what about fuel pressure, mine is set to 32 at idle of 780rpm.
Old Jul 25, 2003 | 09:02 AM
Muckman's Avatar
Moderator in Chief
Are check valves and/or missing link still required if using Hondata or AEM EMS with stock MAP sensor?
Old Jul 25, 2003 | 09:16 AM
platinum00's Avatar
Default Re: code 5 with boost >> (Muckman)
nope. dont need any of that stuff.
teg_95
Apr 28, 2009 07:19 PM
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
kaj
Sep 27, 2003 09:36 AM
platinum00
Jul 24, 2003 08:02 AM
