Code 3 Problem for CRX 91 VTEC Turbo
Old Mar 16, 2003 | 09:55 AM
CiViC SiR's Avatar
Default Code 3 Problem for CRX 91 VTEC Turbo
I have 91 CRX VTEC (B16A) Turbo boost 15psi and having problem with code 3, i'm using missing link for the map sensor and Super AFC for fuel mangement.
so what could be the problem?
Old Mar 16, 2003 | 11:02 AM
inspyral's Avatar
Default Re: Code 3 Problem for CRX 91 VTEC Turbo (CiViC SiR)
I think the Missing Link is only good for about 12lbs of boost. Also, if you're ADDING fuel with the AFC, that will increase your MAP voltage, and it may cause a MAP sensor code if you're adding more than about 10% or so.
Old Mar 16, 2003 | 11:28 AM
Daniel's Avatar
You're at 15 psi and only using a SAFC for fuel management? Upgrade to Hondata or aem ems.
Old Mar 18, 2003 | 09:44 AM
CiViC SiR's Avatar
Default Re: Code 3 Problem for CRX 91 VTEC Turbo (Daniel)
it was working perfectlly for about 7 months with boost 18psi too until i changed my ecu to an automatic transmission ecu. vtec starts at 4500rpm cuts at 7600rpm and speed limit of 180 km
[Modified by CiViC SiR, 9:46 PM 3/18/2003]
Old Mar 23, 2003 | 01:07 PM
CiViC SiR's Avatar
any help please
Old Mar 23, 2003 | 01:18 PM
AbaZ's Avatar
Do you have another map sensor you can try? The missing links are not rated at a specific boost level to fail at.
I'm wondering if its your settings on your AFC. remember, if the Map sees anything over 3.0v it will throw the CEL, does it come on all the time? or just as soon as you boost?
Jeff
Old Mar 23, 2003 | 02:39 PM
IMALLSLO's Avatar
Is the car an automatic?.If its not then change back to a 5 speed ecu for starters. Just curious why you went backward witht the ecu.
Old Mar 23, 2003 | 04:06 PM
Joseph Davis's Avatar
Default Re: Code 3 Problem for CRX 91 VTEC Turbo (proclassracer)
If the ECU has been chipped with a manual program, what the ECU is originally for is irrelevant. It does make me wonder why you switched ECUs, though.
2kdrift
Feb 20, 2010 03:08 PM
DANG YO
Sep 17, 2004 08:01 PM
platinum00
Jul 25, 2003 09:16 AM
CiViC SiR
Mar 18, 2003 09:46 AM
