CODE 16 trouble starting
Old Jul 24, 2005 | 09:50 AM
Turbo_Mike's Avatar
Default CODE 16 trouble starting
Just yesterday i parked my car for an hour in the sun, came out to start it and it hiccuped then wouldnt start. It started throwing a code 16. After a while i reset the ecu and it started up fine. Ended up doing this 3 more times that night. The last time i got gas and shut it off. It started hard but i got it going. PUlled out on the road and it was only revving to 3 grand so i pulled over to reset the ecu again.
I converted from pre to obd1 and i'm using uberdata. All injector clips are on good, and this problem just started yesterday. wHERE can i look to fix this problem?
Old Jul 24, 2005 | 06:54 PM
Turbo_Mike's Avatar
Default Re: CODE 16 trouble starting (MIKE JONES)
Old Jul 25, 2005 | 05:50 AM
boosted k20's Avatar
do u have a resistor box? check that. also pull the fuel rail out with the injectors still attached. have a friend try to crank the car to see if one of the injectors went bad. but check the resistor box if u have one 1st
Old Jul 25, 2005 | 06:25 AM
Turbo_Mike's Avatar
Default Re: CODE 16 trouble starting (boosted k20)
yea i converted to mpfi a few years ago, and i have never had a problem with the resistor box.
Old Jul 25, 2005 | 04:59 PM
Turbo_Mike's Avatar
juanchoenuncrx
11
Apr 4, 2008 07:38 AM
JDM Jimmy
Mar 14, 2004 01:35 PM
Building_rice
Feb 23, 2004 06:11 PM
jdmcrx1
Oct 27, 2003 11:32 AM
pokemon
Jul 26, 2003 09:24 AM
