code 14 and 4 when hit boost?
Old May 29, 2015 | 08:15 PM
93ls10.0's Avatar
Default code 14 and 4 when hit boost?
ok so daily drive my civic at 11lbs not one code problem anything. turn it up to 20 psi tonight to do some testing never made it to full boost and through codes for iacv and ckp I don't know what could cause this? Any had this happen?
96 civic
obd1 jumper
crome pro
basic piston rod b18b
ge intake manifold
76mm Blox tb
Old May 30, 2015 | 07:47 AM
TheShodan's Avatar
Moderator
Default Re: code 14 and 4 when hit boost?
If you are not tuned specifically for up to 20psi, you're going to destroy this engine quickly, never mind any problem codes you're seeing.
Hell. Make sure you've tuned for even 11psi
Old May 31, 2015 | 06:13 AM
93ls10.0's Avatar
It's been tuned for 2.5 bar run it with boost cut set at 21psi same setup for years just never had codes like this come up only in boost. I figured the ckp one just the iacv I don't understand.
Old May 31, 2015 | 05:20 PM
TheShodan's Avatar
Moderator
Hmm. Could be in the software, could be where you're losing voltage somewhere and the computer isn't sure what it is. I've never had codes form running 2.5bar before. I guess this is where you may need to go to the Engine management forum.
Old May 31, 2015 | 05:30 PM
NotARaCist's Avatar
I never narc'd on nobody!
If the codes go away when you reset the ECU (or the car), I'm enclined to agree with the voltage idea. Do you have a voltmeter in your car, or can chrome log voltage for you? What ignition setup do you have? Check and clean all of your grounds, as well - bad grounds can cause funny voltage problems.
Old May 31, 2015 | 10:45 PM
93ls10.0's Avatar
I can't post picture from my phone but it was the sensor pick up on the dizzy shafts for the ckp sheared every other tooth of am actually impressed. Switch it out and all is fine. I have had the iacv code come on before I just turn the sensor off. I also apologize about my last post I worded it back words.
young geezer
May 25, 2016 08:39 PM
honda data
Apr 9, 2010 12:51 PM
beast59
Jan 24, 2010 09:08 PM
wc
Aug 4, 2003 10:35 PM
shadowdawn
Sep 30, 2002 05:59 PM
