clutch alignment tool...needed??
well i need to install my clutch and dont have an alignment tool. can i do it without or do i risk screwing something up.
FSAE
Re: (RTW Ryan)
Any local ricer shop will have a bunch laying around. Call and see if you can get one.
Otherwise, I'm sure someone has one laying around that is willing to send one to you. They come with almost every clutch kit I've seen.
Re: clutch alignment tool...needed?? (RTW Ryan)
Use a broom stick handle and a little bit of eye coordination to center the clutch disk. Works like a charm
I also have a plastic clutch alignment tool if you need it.
Re: clutch alignment tool...needed?? (KayOs)
Just switched a clutch wihtout one yesterday... make the bolts on the PP finger loose so you can just barely slide the clutch around... get it centered the best you can then put the tranny up and it will center once the mainshaft hits the pilot bearing. pull it straight back off and tighten the PP then it will go right on.
Re: clutch alignment tool...needed?? (sackdz)
Or use a socket on and extension........................if slight size adjustment is needed, a little electical tape works.
Mattj.
Mattj.
tacchan
26
03-17-2010 11:25 AM
Black R
05-02-2002 10:23 AM
