clutch problems
Old Dec 16, 2005 | 04:36 PM
mike93eh
Guest
Posts: n/a
Default clutch problems
ok i installed my new ACT clutch. i did it like normal by just unbolting the slave cylinder from the tranny. i didnt disconnect any lines at ALL. when i got it all back together, the clutch fluid HAD to be bled! WHY??
i bled it and it worked fine, but its been sitting a couple days and now the pedal stays ont he floor? ive installed clutches numerous times and dont see why this is happening. there is no fluid loss at all, its at the top line. its been bled many times (even though i shouldnt of had to) so its not that.
Old Dec 16, 2005 | 05:17 PM
t4EK9's Avatar
your master cylinder is going out look under your dash where your clutch pedal is and see if it is leaking or wet around there
Old Dec 16, 2005 | 05:40 PM
mike93eh
Guest
Posts: n/a
no its only 1000 miles old. had no problems right before i started clutch install.. no way it can go out while the car is not being driven for the few hours it took to do the install.
Old Dec 16, 2005 | 09:20 PM
mike93eh
Guest
Posts: n/a
damn this sucks... once i got it bled, it disengaged/engaged like 3/4" from the floor. you know how much that sucks trying to take off in 1st?
Old Dec 17, 2005 | 07:07 AM
prodigymb's Avatar
yeah it does suck taking off from first, did u check all the lines? both slave and master cylinders....those were my problem.
Old Dec 17, 2005 | 07:28 AM
mike93eh
Guest
Posts: n/a
Default Re: (prodigymb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prodigymb &raquo;</TD></TR><TR><TD CLASS="quote">yeah it does suck taking off from first, did u check all the lines? both slave and master cylinders....those were my problem.</TD></TR></TABLE>
ive checked everything..
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
Zerophase
May 8, 2008 02:16 PM
xiztence
Nov 10, 2005 01:37 PM
Dsee2
Oct 23, 2005 10:10 PM
Scooby
Nov 11, 2001 09:07 AM
