clutch or ecu
Old May 16, 2008 | 07:10 AM
riotfish's Avatar
Default clutch or ecu
hey i plan on gettin the go-autoworks.com mini-ram b series turbo kit. but first i need new clutch / ecu. should i get the new ecu or clutch first, i'd rather get one that could improve my stock car so wat would you pick? thanx
Old May 16, 2008 | 07:24 AM
SOHC_MShue's Avatar
Default Re: clutch or ecu (riotfish)
you are gonna need both by the time you boost so plan on getting both of them by then. If you dont have a clutch that can handle the power your clutch will slip and you wont go anywhere and if you dont have a tuned ecu you will probably blow your **** up.
Old May 16, 2008 | 10:51 AM
riotfish's Avatar
Default Re: clutch or ecu (SOHC_MShue)
i know i need both, i was just asking which would make a more noticable change in my stock LS. a new clutch, or a s300 chipped obd1 ecu tuned for my current set up?
Old May 16, 2008 | 11:00 AM
blwn95civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riotfish &raquo;</TD></TR><TR><TD CLASS="quote">i know i need both, i was just asking which would make a more noticable change in my stock LS. a new clutch, or a s300 chipped obd1 ecu tuned for my current set up?</TD></TR></TABLE>
why would u tune your current setup if your planning to boost? or am i confused by what your saying. Your gonna need both before you turbo so i dont see why it matters which u get first. Buy the s300 and it sits until your ready to go get tuned... buy a clutch and put it in and drive it, then buy s300 until it gets tuned either way it doesnt matter
Old May 16, 2008 | 11:11 AM
.dave's Avatar
i HAS questions ?
I would say get the clutch, install it and make sure it works on your current setup. Its one less thing you'll have to worry about/troubleshoot once the turbo is installed. Make sure you pick up the S300 and get it tuned before you go around boosting and beating on it though.
Old May 16, 2008 | 12:10 PM
riotfish's Avatar
Default Re: clutch or ecu (.dave)
oh i didnt know if i could get the s300 tuned for a stock car, to improve my fuel control and maybe get me more hp or something. but thanks ima take the advice and install the clutch now and just hold the s300.
Old May 16, 2008 | 12:20 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riotfish &raquo;</TD></TR><TR><TD CLASS="quote">oh i didnt know if i could get the s300 tuned for a stock car, to improve my fuel control and maybe get me more hp or something. but thanks ima take the advice and install the clutch now and just hold the s300.</TD></TR></TABLE>
You could, but to me its not worth it. You would see some gains, but why bother shelling out the cash to get it tuned when you'll have to do it again after the turbo is installed?
Old May 16, 2008 | 01:18 PM
riotfish's Avatar
yea true with that $300 or w/e i could put that towards the exhaust ima need to fit the 3in downpipe
g-dan90
Nov 15, 2009 12:57 PM
artevo9
May 5, 2009 02:45 PM
blackstar
Jun 16, 2008 05:54 PM
TypeSFTW
16
Mar 13, 2008 05:50 PM
eag36
Sep 26, 2005 02:16 AM
