Closed Loop or Opened Loop Wastegate??
Old Mar 25, 2003 | 04:19 PM
  #26
SiRkid's Avatar
Default Re: Closed Loop or Opened Loop Wastegate?? (ntegls)
holy old
Old Mar 25, 2003 | 04:57 PM
  #27
turbo Si's Avatar
Default Re: Closed Loop or Opened Loop Wastegate?? (SiRkid)
Why don't you just make a pipe and extened it downward like everyone else.......always trying to be different !
Old Mar 25, 2003 | 04:59 PM
  #28
turbo Si's Avatar
Default Re: Closed Loop or Opened Loop Wastegate?? (Diego Boost)
WHY THE HELL DID YOU EVEN BRING THIS BACK UP???????
Old Mar 25, 2003 | 05:03 PM
  #29
falcongsr's Avatar
What is this crap?
Default Re: Closed Loop or Opened Loop Wastegate?? (sol-racer)
Why 18"? Can't I offset that number by going with a bigger downpipe... say 9" w/ a 3" exhaust and even closer if I go 4" dp to a 3" exhaust?
i dont think thats a good rule to make up....you dont want to disturb the flow of gases as the exit the turbine. the turbulance will cause a pressure rise and will slow the spooling of the turbo as well as raise the backpressure at the turbine outlet. i wouldnt do it anywhere near the turbine exit even with a 3" downpipe.
i think the best place to practically do it is if you have a 2.5" downpipe is anywhere at or after the bend under the oil pan, preferably near the back of the oil pan where you can flare out to 3" for a 3" exhaust.
Old Mar 25, 2003 | 05:22 PM
  #30
Bailhatch's Avatar
Default Re: Closed Loop or Opened Loop Wastegate?? (falconGSR)
What about putting a small engine muffler on it. lawnmower, motor scooter, etc.... It could be stealth and a good alternative for people with smaller DPs. You might even get some pretty cool sounds by changing the pipe length and muffler type (resonator/glasspack, baffles). just an idea for an old thread.....
Old Mar 26, 2003 | 03:00 PM
  #31
falcongsr's Avatar
What is this crap?
Default Re: Closed Loop or Opened Loop Wastegate?? (Bailhatch)
thats what older porsche turbos have.
Old Mar 26, 2003 | 03:34 PM
  #32
Diego Boost's Avatar
Default Re: Closed Loop or Opened Loop Wastegate?? (turbo Si)
BECAUSE I'M RE-ROUTING MY DUMP TUBE AND I WANTED MORE OPINIONS ON THIS SUBJECT!!!!!!
kauai96
Jun 2, 2008 12:45 PM
00BoostedGSR
Aug 15, 2006 02:46 PM
ThePunk
Jun 25, 2003 09:48 AM
MyWhiteCivic
Sep 21, 2002 12:36 PM
92HB_HB
May 15, 2002 04:48 PM
