clocking turbo, i searched
Old Jul 23, 2004 | 09:02 AM
Btothe3rdDegree's Avatar
Default clocking turbo, i searched
hey guys i am trying to clock my exhuast side of my t3 and the lil biatch wont turn i loosened the bolts as far as they would go (cant take them out all the way because they hit the oil and coolant holes) and put it in a vise and stuck a big ol srew driver down the exhaust housing and it still wont budge, any ideas?
Old Jul 23, 2004 | 09:29 AM
boosted92's Avatar
Default Re: clocking turbo, i searched (Btothe3rdDegree)
anti-seize
Old Jul 23, 2004 | 10:04 AM
TeamCracka's Avatar
Default Re: clocking turbo, i searched (boosted92)
Try a rubber mallet, or just put a towel on it and beat it with a hammer.
And anti-seize will deteriorate in with the extreme heat. I tried using it once and it was gone after a few months. You wont have any problems with bolts seizing as long as you run the car regularly (to get the bolt expansion/contraction from heat cycles, and theres no way waters going to get in there).
Old Jul 23, 2004 | 10:36 AM
Foowee's Avatar
Soak it in penetrating oil, then hit it with a hammer.
If that doesn't work..... Try to get your hands on an oxy/acetelene torch. Heat up the perimeter of the tubine housing so it expands away from the cartridge. Then hit it with a hammer. Oh yeah, I prefer a lead hammer.
As for reassemblely... Loctite C5-A. It's a copper based anti-sieze thats supposed to be good to 1800 deg.
Old Jul 23, 2004 | 12:32 PM
Bailhatch's Avatar
Default Re: clocking turbo, i searched (Foowee)
I built a tool for clocking old t3s i get at the yard. its basicly a 1.5" steel pipe about 3.5 feet long. on one end I welded a 1" x 1/4" x 4" plate and drilled holes that corespond with the drain flange holes. I bolt it on with some grade8 bolts, throw the turbine housing in the vise, lube her up and usually just put some weight into it and it turns. Use a little heat as nesscary and lots of PB blaster
D15Bbigred
May 18, 2007 03:03 PM
LaOstha
Nov 30, 2006 06:54 PM
delslo93
Jan 23, 2005 12:31 PM
drumking15
Apr 20, 2003 02:37 PM
B18C-RnVA
Sep 15, 2002 06:59 PM
