clocking the compressor???
Old Mar 19, 2004 | 07:32 PM
5STAR3's Avatar
Default clocking the compressor???
i know how to clock a turbo. Im trying to clock my brand new t3/to4e and i cant get the compressor to turn?
any ideas? does it take some force?
Old Mar 19, 2004 | 07:36 PM
RenoRacing's Avatar
Default Re: clocking the compressor??? (envision2teg)
yeah, loosen all the bolts a few turn and sometimes it requires sticking a ratchet in the outlet hole of the compressor to get a little leverage.
Old Mar 19, 2004 | 07:40 PM
5STAR3's Avatar
Default Re: clocking the compressor??? (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing &raquo;</TD></TR><TR><TD CLASS="quote">yeah, loosen all the bolts a few turn and sometimes it requires sticking a ratchet in the outlet hole of the compressor to get a little leverage.</TD></TR></TABLE>
ok, so its ok to give it a little force
Old Mar 19, 2004 | 07:41 PM
GForceInteg's Avatar
I dont know what clocking is if anyon would mind elaborating.
Old Mar 19, 2004 | 07:44 PM
RenoRacing's Avatar
Default Re: clocking the compressor??? (GForceInteg)
it's just a term used to describe the rotating of the compressor or turbine on a turbo to maintain the vertical position of the center section and allowing you to "aim" the housings.
Old Mar 19, 2004 | 07:45 PM
RenoRacing's Avatar
yeah, some force is required, rap the ratchet in a rag or something, just to cusion it against the aluminum of the compressor outlet. once you get it going the first time it'll free up a little more.
rondigs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg &raquo;</TD></TR><TR><TD CLASS="quote">I dont know what clocking is if anyon would mind elaborating.</TD></TR></TABLE>
...just talked about this earlier. H-T has a great search function:
this link was the first to come up under "clocking"
https://honda-tech.com/zerothread?id=734165
Old Mar 19, 2004 | 07:49 PM
5STAR3's Avatar
Default Re: clocking the compressor??? (rondigs)
well how much pressure should i be putting on it.
im standing on the manifold, and pulling as hard as i can, at an awkward angle. but i am pulling pretty damn tough.
ill get it in a vice tomorrow, but am kinda scared to put too much force into it.
Old Mar 19, 2004 | 07:58 PM
RenoRacing's Avatar
you loosened the bolts right? just asking to be safe?
Old Mar 19, 2004 | 08:01 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing &raquo;</TD></TR><TR><TD CLASS="quote">you loosened the bolts right? just asking to be safe?</TD></TR></TABLE>
lol, yea. the weird thing is, is i have rotated used turbo compressors that wa WAAAAYYYY easier than this.
i reall cant get it to move, i can get it to slip like 1/2 inch, but thats it.
Old Mar 19, 2004 | 08:59 PM
J337_UNIT's Avatar
i had the same problem.. i took a rubber mallet and loosened the bolts evenly ALOT like 1 turn before they would come out.. then i hit the bolts directly very lightly and the compressor will start to come off..but u dont want to pull it off, just enough so that it will move alittle more freely. just be careful, you dont want to hit the compressor housing against the blades and damage them..
Old Mar 19, 2004 | 09:00 PM
5STAR3's Avatar
Default Re: clocking the compressor??? (J337_UNIT)
why is it bad for the housing to come off?
Old Mar 21, 2004 | 03:43 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">why is it bad for the housing to come off?</TD></TR></TABLE>
its not bad, you just may accidently angle the compressor housing enough so that it damages the blades.
Old Mar 21, 2004 | 03:48 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
its not bad, you just may accidently angle the compressor housing enough so that it damages the blades.</TD></TR></TABLE>
yea i talked to arturbo and he told me to tap it off with a rubber hammer. thats what i did and it worked great
Soon_2b_evil
Feb 3, 2006 06:16 AM
dnbruut
Jul 8, 2005 07:57 AM
94EGhatch
Aug 16, 2004 07:50 AM
DigitalFusion
Oct 30, 2003 06:13 PM
PM-Performance
Dec 9, 2002 08:43 AM
