Cleaning the crankshaft
Old May 25, 2007 | 08:58 AM
turbodohcsi's Avatar
Default Cleaning the crankshaft
Ok, so im cleaning parts to get them ready for assembly, so now im working on the crank and due to other visual evidence i have had i know there is most likely metal debris behind those little silver ***** in the counter weights. Well the only way ive seen this spot cleaned out before is by drilling out those ***** and cleaning and then rewelding some stock back in there to plug up the holes. Well i dont want to go through all that again so im looking for ideas on how to clean behind them *****.... fire away!
Old May 25, 2007 | 09:32 AM
PrecisionH23a's Avatar
Default Re: Cleaning the crankshaft (turbodohcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi &raquo;</TD></TR><TR><TD CLASS="quote">so im looking for ideas on how to clean behind them *****....
Quote of the year. Have you considered having it hot-tanked?
Old May 25, 2007 | 09:36 AM
lol, yeah, i think i should try to reword that, but ill let it "hang" around for a little bit. But anyways, everything you can see on the crank is clean, but everytime i have seen the silver ***** removed there is been metal built up behind them. So i just dont feel secure putting a crank that could be housing metal into my motor, ya know? I would rather know there is nothing there.
Old May 25, 2007 | 11:04 AM
come on yall, tell me im not the only one that wants to clean out behind my *****!
Old May 25, 2007 | 04:36 PM
Dartanian's Avatar
By *****, you mean oil galley plugs?
The only way is to have a machine shop drill them out and clean them out thoroughly and then have some removable allen caps tapped in and loctited.
Old May 25, 2007 | 06:15 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Dartanian)
I just squirt some brake cleaner up there.
Old May 25, 2007 | 06:32 PM
:Josh:'s Avatar
Default Re: (Muckman)
I've tried all of the above and the only one that works for me is to actually remove the ***** and clean behind them. I actually left a pretty clean crank in a hot tank for 2 or 3 hours and then removed the ***** and there was still about an 1/8" of crud in there. I usually just tig a little tower of metal onto the ball and use a pair of dykes to pop it out then replace the ***** with new ones.
Old May 25, 2007 | 07:35 PM
NJIN BUILDR's Avatar
Default Re: (:Josh:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Josh: &raquo;</TD></TR><TR><TD CLASS="quote">I've tried all of the above and the only one that works for me is to actually remove the ***** and clean behind them. I actually left a pretty clean crank in a hot tank for 2 or 3 hours and then removed the ***** and there was still about an 1/8" of crud in there. I usually just tig a little tower of metal onto the ball and use a pair of dykes to pop it out then replace the ***** with new ones.</TD></TR></TABLE>
That's your answer ^^^. Remove them and tap the hole for a pipe plug.
Old May 25, 2007 | 09:31 PM
V-SPEC 1's Avatar
Default Re: (NJIN BUILDR)
would the crank won't get out of balance by doing that?
Old May 25, 2007 | 09:55 PM
Runnerdown's Avatar
Default Re: (V-SPEC 1)
I send every crank to the machine shop to get those removed, tapped and rebalanced. So much crap collects there.....
Old May 26, 2007 | 12:20 AM
tony413's Avatar
look in my sig or search for cleaning write-up the one i put in the tech section is great and cost $20 and works comparable to hot tanking go take a look
Old May 26, 2007 | 12:34 AM
yeah, i was worried about drilling and tapping, cause it is a good idea to have it rebalanced after that. But i guess i got to do what i got to do, anyone near atl that wants to drill them out for me?
Old May 26, 2007 | 05:47 PM
For those of you who drill the plugs out.. how do you get the drill bit started? How do you make a dent in them things so the bit doesnt keep sliding off to the side. And do you have to use a carbide tipped bit, or will a normal drill bit cut through them things.
Old May 26, 2007 | 07:01 PM
V-SPEC 1's Avatar
Default Re: (turbodohcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi &raquo;</TD></TR><TR><TD CLASS="quote">For those of you who drill the plugs out.. how do you get the drill bit started? How do you make a dent in them things so the bit doesnt keep sliding off to the side. And do you have to use a carbide tipped bit, or will a normal drill bit cut through them things.</TD></TR></TABLE> same question here.
Old May 26, 2007 | 09:52 PM
I haven't had much luck drilling them out.Tig welding a "handle" on them seems to work out best.
Old May 27, 2007 | 07:06 PM
T Dohc's Avatar
Chris you know mac can do it, he did it to mine. Just tring to catch him in town is the fun part.
Old May 28, 2007 | 08:31 AM
He keeps saying he doesnt have the time.
Flux
Oct 25, 2006 08:11 PM
pinkspider
Mar 2, 2006 11:56 AM
Cuong-nutz
16
Apr 2, 2005 07:50 PM
Stunna BEN
Aug 26, 2004 09:54 AM
moleodonuts
20
Jun 26, 2004 07:49 AM
